Question about Dell (0F146) Internal DVD Drive
Dell cd rom drive cannot detect - Dell (0F146) Internal DVD Drive
    Sergeant:
  • 192 Answers
Try to clean it our install the OS you are using.. to repair it...
Posted on Aug 23, 2010
Dell Inspiron 1501 CD-Rom wont play.I can hear it start to spin.Can play stored music.Have no CD Rom or filters showing under "Device manager".
If the CD-ROM drive is not being detected under the device manager, chances are that either the power/data cable is loose or the drive is dying. To check the cables, turn off the power, unplug the power cord, open the case and examine the two plugs behind the drive. Touch yourself to something metal first to discharge static electricity.
If it turns out the drive is dead, then luckily drives are usually very cheap to replace. Somewhere in the line of $15 usually.
Mar 07, 2011 | Dell (6T980-A01) CD-ROM Drive
Hi.. i am using a dell 1545 inspiron. the cd rom worked perfectly some time back but recently it stoped.1st the writer stoped workin later the cd rom reads and detectes the cd but it says its blank. plz...
Hello and Welcome to Fixya.
Seems like you're having a software issue that prevents your system to read/run a disc when inside the operating system. I have included the official fix from Microsoft:
DVD Drive Troubleshooting
All you have to do is to click on "Run Now" and follow the on screen prompts - just remember to eject any CD that you may have inside the drive.
Please note that if this does not work, then the drive needs to be replaced. You may contact dell in case that happens.
Hope this helps and Thanks for using FixYa.
Feb 22, 2011 | Dell DVD-rom DVD Drive
Dell Dimension 8200 PC Desktop Cd rom not reading disk
optical drive troubleshooting is pretty straight forward, fist see if you can boot to the drive using a bootable CD like the Windows CD or your Dell Resource CD, use the F12 1 time boot menu test it.
Also see if the drive is detected by model in the BIOS (F2 at boot) if not seen, reseat both power and data cables, boot to BIOS F2, turn on CAP LOCK SCROLL LOCK, NUMLOCK, then press ALT+E then ALT+F then ALT+B, this resets bios defaults and forces hardware re-detection. If you have no floppy diskette drive, you'll need to turn that back off in the BIOS before the ALT+B
If all that is done and the drive isn't seen/cannot boot to with bootable media, swap the data cable with the HDD and try a different power connection.
If Drive still not connected, replaced the drive.
If drive is detected and IDd then try this
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Jan 28, 2011 | Dell Dimension 8200 PC Desktop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Internal hard drive not found dell inspirion
Try re-booting the system in safe mode and go to my computer->manage->hard drive..try to refresh it from there.
Sep 05, 2009 | Dell Inspiron 2200 Notebook
Dvdrw can not detect in dell astro 1400 notebook
Check your system BIOS whether it is Detected there, if no, Shutdown your system, Press your CD-Rom drive towards the system firmly (Incase its making a partial contact), and restart your system. If Yes, then Start your system, Right-Click on my computer, go to properties, Device Manager, DVD/CDRom Drives. and click on it. if your CD Rom Drive is not detected there, then on the Device Manager Screen, click on Action, Scan for hardware changes, your system should detect it automatically. But if its already there, right-click on it, Uninstall it and do the scan system for hardware changes again. It should solve the problem like that.
Jul 10, 2009 | Dell Vostro 1400 Notebook
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
NOT DETECTING CD ROM
Although the BIOS in this old machine has a boot from cd option, it is quite possible the DVDrom drive simply doesn't support the feature. Many P2 machines were like that. Chances are you will need a bootable DOS/WIN95/WIN98 floopy which will allow you to get it running with a CD driver.
Once you have this accomplished you can simply use the command prompt with cd support boot option and use the command prompt to load the installer on the CD. Once it finishes it's initial setup it will be able to use the cd drive for everything BUT booting.
Hope this Helps FixYa,
Chris
May 20, 2009 | Dell Computers & Internet
Dell c640 Latitude , CD ROM detected but no content displayed
please check it in different CD or DVD. then check it in a another cd drive attaching to ur laptop. otherwise format your laptop it may be infected with some virus
Mar 20, 2009 | Dell Latitude C640 Notebook
Dell GX60 CD-ROM will not copy
Hi, this issue may occur if the firmware is not installed. Please Click on start>>> run >>> type devmgmt.msc and hit enter.
Look under DVD drive. You should find the name of the driver. Search for available firmware at support.dell.com by either entering the service tag of the computer or by product type. That should make it work.
If not, try in safe mode. If that too does not work, call Dell tech and mention the steps and ask for a replacement. YOu will get it in no time if system is under warranty
Please rate if useful
Sep 18, 2008 | Dell Computers & Internet
Dell (0F146) Internal DVD Drive Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
