Question about RCA WSP155 Main / Stereo Speaker
Voice is not coming out from my right stereo speaker and my left speaker stop working some times ..what did i do SIR.
    Sergeant:
  • 192 Answers
Check the wires for the loose connections..
Posted on Aug 23, 2010
Diagram of stereo wiring in a 1997 Chevy S-10 Blazer
Hi there:
Check this on 1998 Chevrolet S10 Blazer Car Stereo Radio Wiring Diagram:
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 12, 2012 | Chevrolet Blazer Cars & Trucks
2005 nissan pathfinder xe 8 speaker wiring COLOR
Check this for...
2005 Nissan Pathfinder with Bose Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: Green
Car Stereo Amp Trigger Wire: Green
Car Stereo Amplifier Location: Under the Driver Seat
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
2005 Nissan Pathfinder Car Radio Wiring Diagram
Left Front Speaker Positive Wire (+): Brown
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Dec 20, 2011 | 2005 Nissan Pathfinder
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
Sep 12, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
I have a Onkyo TX-8222 receiver. Sound is ok for music but voices are very low. When two voices, one is very clear abd the other very low. What is the problem ?
You don't say what source(s) are affected. I'm guessing TV or Cable-TV is the problem because music with vocals has voices and you say it sounds ok. Your speakers have no clue whether a sound is a voice or music so that lets THEM out and your receiver doesn't know or care either.
In the modern multichannel world it's usually assumed your electronics are multichannel. This receiver is old-school stereo.
The Center channel is usually where voices are found but some systems (like yours) don't have a Center speaker so they have to be configured to share the Center duty with the front left and Right speakers.This isn't possible or even normally necessary in your case. WYSIWYG
http://www.retrevo.com/support/Onkyo-TX-8222-Receivers-manual/id/469ci869/t/2/
The audio coming in from 'wherever' should be correctly mixed to 2-channels at the source or you'll probably be missing something. I'd look higher up the audio food chain for where the voices are being attentuated. If a cable box is involved I'd look at its audio settings regarding stereo mix-down
Wait, I just had an inspiring thought. Centered voices being mono in nature would partially cancel out if your two speakers were out of 'phase' with each other. Bass would also suffer. Make sure your two speakers are wired identically regarding the red and black (or plus and minus) conductors. If turning the Balance control fully to one side makes bass of voices sound louder you probably have a phase mismatch. Reverse the wiring on either speaker to match the other. There is no absolute right or wrong for phasing as long as they're all the same.
Dec 31, 2010 | Onkyo GX-D90 Main / Stereo Speaker
Factory stereo wiring
Right here!
1986 Ford Ranger Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Mar 04, 2010 | 1986 Ford Ranger 2WD
BUTCHERED WIRING.
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Audio Front Speakers Size: 5 1/4′
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Jun 02, 2009 | Car Audio & Video
Audio output
I have the same issue if I connect my digial audio cable from the Yamaha receiver directly to the HDTV. But, I get all 6 speakers working when I connect the Yamaha receiver directly to the Comcast HD box (instead of TV).
Dec 11, 2008 | Yamaha HTR-5650 Receiver
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
RCA WSP155 Main / Stereo Speaker Logo
53 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
