Question about RCA HD61LPW175 61" Rear Projection HDTV
Black Screan RCA HD61LPW175 we heard a loud sound almost like a light bulb breaking and now screan is solid black but continues to turn on and has sound
  • 1 more comment
  • ALLBOIZ Aug 16, 2008
    TV TURNS ON SOUND IS FINE BUT NO PICTURE AND IT MAKES AN ALARM SOUND FROM BACK OF TV
  • jenniferleco Jan 22, 2009
    You can hear the tv, but there is no picture and the small blue light in the bottom right hand corner is flashing...if it's the matter of changing the bulb, how is this done and where would I go to find a bulb?...I would so appreciate it if someone could help...thanks...
  • joysam7 Feb 24, 2009
    my 61" dlp rca tv is making a buzzing sound and not coming on
    there is no picture
  • RCA Master
  • 8,617 Answers
THe lamp has shatterd inside its housing. remove the broken lamp and replace with a new one that should solve the problem
Posted on May 04, 2008
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
I am powering up and the flat screan turns on and
More likely to be bad caps (bulging top/seal) in the power supply, which when they failed, they may have taken out the inverter fuse on the transistors in the inverter circuits also. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
The screan is black, there is no emages and battery is chargeed
Turn the screen so that there is some light shining from a window across the screen
Can you see an image , if so the backlight has gone and either needs an inverter or a new light
If there is no image try plugging a normal monitor into the outlet port on the side of the notebook
Still no image then the graphics section has gone down and you will probably need a new motherboard
Jan 08, 2010 | Toshiba Satellite A135-S4527 Notebook
TV WILL NOT TURN ON RCA GREEN LIGHT ON POWER FLASHES
That would be your bulb.
Most bulbs have a limited life and on projection screan televisions.
The cost is pretty resonable though and are about in the 200.00 range.
Oct 23, 2009 | RCA HD52W56 52" Rear Projection HDTV
Screan gone black, but the phone works
Your LCD screen is broken. If you have insurance on the phone, you can have the phone replaced. If not, you have voided the warranty by breaking the screen.
You can find a replacement screen at:
http://cgi.ebay.com/LCD-Display-Screen-for-LG-KU990-KU-990-KE998-Viewty_W0QQitemZ120405276035QQcmdZViewItemQQptZPDA_Accessories?hash=item1c08b6b583&_trksid=p3286.c0.m14
Instructions for taking apart the Viewty are:
http://disassembly.wordpress.com/2009/08/03/lg-viewty-ku990-disassembly/
IF YOU ARE NOT COMFORTABLE TAKING APART YOUR PHONE...DONT! Take it to someone that is. Remember, if you have insurance on your phone, they will not replace it if it has a cracked screen, they will replace it if it is lost.
If I have helped you, please give me a good rating. It allows me to help others. Thank You.
Aug 07, 2009 | LG KU990 Viewty
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
I have no idea so if you can help thanks
The board on the left will have a series of small aluminum heatsinks with black ICs attached to them one of them will be the vertical output IC with about 7 pins on it. try resoldering those ICs and you should get the picture back as the vertical ICs will make the tubes cut off. The vertical IC should be marked on the board but solder all the ICs mounted to heat sinks on that board to be safe.
May 13, 2008 | Mitsubishi VS-6043 60" Rear Projection...
RCA HD61LPW175 61" Rear Projection HDTV Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
