Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
My bissell steam cleaner will not spray any water or soap how do I correct this problem
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjgtllgj
Posted on Sep 30, 2010
When I feel the bottle with cleaning solution and install it on the machine the water runs right thru the machine and onto the floor without pulling the trigger?
Posted on Sep 06, 2012
5 Suggested Answers
  • 61 Answers
SOURCE: Have a bissell pro steam cleaner the suction is
Use this guide!
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Troubleshooting_ProHeat2X_9400F.pdf
Posted on Apr 15, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Vac Belts
  • 701 Answers
SOURCE: ProHeat Turbo Deep Cleaner Upright Steam Vacuum: Hello, My Bissell Proheat is not spraying water, ...
Most likely the pump belt is worn and needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: i have a bissell steam cleaner. the hand piece
heatman101
a
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissell steam cleaner. the hand piece
heatman101
a
Sep 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell steam cleaner model 9300 not putting out soap
heatman101
,b..,
May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My steam machine will not spray water on to carpet why
clean the heater out it may be clogged with dry soap and water
Dec 28, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
1,189 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
