After inserting sim it shows Sim Card Missing Error
    Sergeant:
  • 192 Answers
Maybe your Sim is broken already our it is expired..
Posted on Aug 23, 2010
Insert sim card 5320
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Nokia shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Nokia 5320. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Jul 24, 2013 | RIM Cell Phones
Sim card missing
Use a different SIM card and reboot, If gives the same error kindly contact Nokia Care.
Aug 28, 2012 | Nokia 100 RH-130 CV UK FESTIVAL PINK
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Invalid sim card
It shows Sim Error or else Invalid Sim...Or even though Sim Inserted it asks "Insert Sim"
If it says anyone of the error like that means Your Mobile is Locked To Network ..You need T Unlock it to insert other Network Sim GSM Sim Card....
It may locked to some Network....You can get the code here
http://www.superunlockcodes.com/supported-phones/rs12wp7/ and Unlock the Mobile from the Network Lock....
I hope..You got solution...
Jan 21, 2011 | Cell Phones
My samsung tocco has full signal but screen shows sos calls
its because of sim card error please insert some other sim card and on it for at least 5 hour once mobile frequency clock will set to new sim card then re insert old sim card it will take effect 100 %
Dec 18, 2010 | Cell Phones
Inncorrect SIM card.
  • Clean the connectors on the SIM card with a soft brush, cloth or q-tip moistened with any type of unflavoured, colourless alcohol.
  • Check whether the card is damaged or worn in any way.
If your SIM card is damaged or does not work properly after cleaning, please contact your operator to obtain a new SIM card.
Error message Insert Correct SIM
Your phone is probably SIM-locked to a specific operator's SIM card. This is usually the case when you buy the phone from an operator. SIM- locked phones may be unlocked – contact your operator for more information.
Jan 09, 2010 | Sony Ericsson K610i Cellular Phone
Sim card in . but comming up insert sim
If it still showing insert sim, you can get a rubber eraser and erase the sim's chip. Also rub eraser on the part of the phone where sim is inserted.
Try to insert other sim cards if it is showing the same error. If yes, then you need to clean that part of the phone where sim is inserted. Try the rubber eraser technique. If it does not work, have a soft earbud cotton and dip in alcohol then gently rub it on that part.
Sep 01, 2009 | Motorola Mobility L6I Cellular Phone
My mobile shows sim card missing model no 3315 htc windows mobile
Makme sure the sim card is inserted correctly and also try removing it and clean the chipset with a celan cloth. Also try checkin your sim card with another phone to make sure it is not (the sim card) destroyed.
Aug 19, 2009 | HTC Cell Phones
No sim card inserted?
no sim card error is not virtual error from service providers, its due to your phone hardware problem. if your sim was not working due to service provider it will show your card registration failed. but you are getting sim card not inserted means your sim card contacts are not touching the phone sim contacts. try to refix your sim card properly. then try to reboot your phone.
Feb 26, 2009 | Nokia 6300 Cellular Phone
Treo 650 not able to access sim card
The SIM card is dirty or scratched.
Try taking the SIM out and wiping it with a dry cloth... then insert it back in firmly. If that does not work, you may need to replace the SIM card, or find a way to get it to press itself more firmly against the phone.
- J.
Feb 26, 2008 | Palm Treo 650 Handheld
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
