Question about Casio G-Shock GW300CA-1V Wrist Watch
How does LED light with afterglow looks like?
  • 831 Answers
Your question can be answered here:
http://www.casio.com/products/timepiece/g-shock/
Posted on Aug 23, 2010
Samsung55in led tv. 7100 series. After a few minutes of being on the picture goes off. But the Samsung power indicator light remains on.
No doubt. Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 28, 2015 | Samsung UN55ES7100 55" Series 7 LED 3D...
Star Wars rebels led watch how to set time and date
Hi,I had the same problem. Look on the side of the watch on the right, in between the two pressable buttons. There is a small black button, size of a Byro tip. Press that in for 5 secs then the date display will start to flash. Set with the lower big button then press the small button again to cycle through month, day, hour, minute.
Phew. Takes a bit of spotting.
Mar 14, 2015 | Watches
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Ohsen AD0721 will not light up
bad led light or low battery.it takes away functions
Jan 31, 2012 | Watches
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
I lost my Dakota Torch REQ SOS with solid cover/shield. I am trying to find another. I have the charger for it.
Here's a link directly to the Dakota website for this particular brand of watch:
https://dakota.webfeatsecurity.com/watches.aspx?sr=t&Series=25
I looked briefly on E-bay and only saw one available auction for this type of watch, here's the link (it's shortened because E-bay links are huuuuge)
http://goo.gl/gpqq9
May 02, 2011 | Dakota REQ Torch LED Light & Watch
Hello i changed the battery on my dakota angler II and the only thing that works is the red light, no time analog and or digita, none of the buttons do anything except the red one for the light.
Did you change the battery yourself? Did you have instructions? The reason I ask is only because some watches/etc have more the one battery for various functions. Sometimes there are more batteries underneatch the battery you replaced.
I would call the manufacturer and ask them if you have the number.
Jul 22, 2010 | Dakota Angler II 3864-9 Pendant Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
363 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
