Question about Refrigerators
Ge profile refrigerator tpx21prxd 1996 side/side Refrigerator side keeps freezing everything no matter what setting. I found a random spring I think holds the trap door in air damper control closed. However. replacing this doesn't help. weird part is top shelf will get frost but bottom shelf and crispers freeze. This has been going on for over 4 months. 2 months prior the indoor ice maker door would open and close randomly as if someone was trying to get ice. I put a piece of dense foam over the hole to save energy and it stopped opening and closing. Thanks- Andrew
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
  • 531 Answers
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Posted on Apr 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
SOURCE: GE Adora Side by Side Refrigerator Ice maker
We had the same problem, our is four years old and for three years, water would run down from the bin and freeze on the back wall. It finally turned out that our unit did not have the sensor in the freezer part from the factory. Once this was installed, it has worked fine.
Posted on Aug 17, 2009
Refrigerator side keeps changing to lower temp
I think your thermostat is defect. Not registering the correct temperature. dial in a higher temp for the time being, but (let) replace the thermostat.
Jul 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
Ge side by side profile Artica, the bottom drawer on the fridg side keeps running and freezing everything. I can't seem to shut it off. Please help!
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The refrigerator freezes everything
Faulty thermostat. Replace or keep lowering temperature setting.
Jul 08, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Need your opinion on buying a new GE Profile refrigerator.
no dont do it GE is just bad news . if you must by ge make suer you buy the extended warr .and keep it current YOU WILL NEED IT ! ....... what one should buy? it does not matter , there all the same refrig inside ,just just STYLE you pick DONT FORGET EXTENDED SERVICE PLAN !
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
