Question about Ammco Combination Disc/Drum Brake Lathe
Want to know the difference between ammco 4000 and 4000B brake lathe
3 Suggested Answers
1fastbob
  • 301 Answers
SOURCE: I HAVE AN AMMCO 4000 BRAKE LATHE AND WOULD LIKE TO
http://cgi.ebay.com/ebaymotors/Ammco-4000-Brake-Lathe-Operating-Manual_W0QQcmdZViewItemQQitemZ360197546157QQptZMotorsQ5fAutomotiveQ5fTools
You might try buying a manual for it. There is one on E-bay right now. might be $14.00 well spent.
Hope this helps.
Bob
Posted on Oct 28, 2009
  • 1509 Answers
SOURCE: MY AMMCO BRAKE LATHE IS CUTTING EVEN,BUT LEAVING SMALL GROOVES
The problem isn't clearly explained. but the main shaft bearings go bad after awhile and it's one day thier good the next job their bad.
Posted on May 13, 2010
AMCCO 4000 BRAKE LATHE CHATTERS WHILE TURNING ROTORS
Not enough rigidity, wrong speed, wrong feed rate, wrong depth of cut, wrong or dull tooling...
Feb 03, 2012 | Ammco Combination Disc/Drum Brake Lathe
Ammco
Most likely you have a stripped out "disc feed screw."
This is a common problem I see several times a month in the field.
The stripped out portion of the screw is near the end of the feed range obviously.
If you need parts or more questions answered....
Buy Sell Used Brake Lathes Brake Lathe Parts
Jan 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Instructions for changing an ammco 3000 brake lathe to a 4000. Parts needed?
Yes, an Ammco 3000 brake lathe can be converted over to a 4000 model--most any year 3000.... preferably the later years after 1970.
The problem with some of the early 60's models is that the cross-feed bore is not perfectly perpendicular to the spindle.
If you convert one of these models, you will cut the rotor at an angle and then jam the machine.
Later models can easily be converted.
You will need...
1) A complete disc feed gearbox.
2) A driven pulley (the big one) set-up for a with a pin drive.
3) A complete spindle lock assembly for the Infimatic gearbox.
4) Possibly need a longer guide bar for the cross-freed. If you have a round guide bar, this is possibly long enough. If you have a "Double-D" guide bar (flat on each side), you most likely will need a longer bar.
5) A complete twin-cutter, with tool guides, tool holders, knobs, etc.
We have all the parts you need for a conversion--or we can convert it expertly for you...
Aug 03, 2011 | Ammco Combination Disc/Drum Brake Lathe
May 13, 2010 | Ammco Combination Disc/Drum Brake Lathe
I need a manual to repair my tos trencin lathe sn-40a
I am looking for a tos trencin taper attachment for a 20" lathe. Got any ideas?
Apr 15, 2010 | Ammco Combination Disc/Drum Brake Lathe
I got an ammco 3000 i just have 1 bit on it and i dont have any item number on boring bar,bit holder i just have the bit size that is a little bit small than 7/16 that is 55/128 from base(bottom)to the...
If you live near a machine shop any lathe operator can steer you in the right direction, or you could call them. I'm not certain if Ammco is still in business. I had the same machine in my shop in 1976, not the same model # of course, but a model with the stand.
Aug 22, 2009 | Ammco Combination Disc/Drum Brake Lathe
Open Questions:
See all Ammco Combination Disc/Drum Brake Lathe Questions
Ammco Combination Disc/Drum Brake Lathe Logo
146 people viewed this question
Top Ammco Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Ammco Tool and Hardware - Other Expert? Answer questions, earn points and help others
