Question about Goodman CKL30AR30 Air Conditioner
I have a goodman cpe30-1ab we set it to cool the out side pump and fan run about 5min and shut down the power relay starts to buzz and the fan moter gets hot real hot. all three wires to the fan have 110 to120 volts but fan nor pump will come on . if i go inside turn switch from cool to off wait a while then go back to coll it runns about 5min shuts down
  • markgairson Aug 24, 2010
    i have had fan out and it turns free when it first comes on it runs ok after it shuts down it tries to restart then is when it gets hot
  • 674 Answers
This could be several things. First turn of the power and make sure the fan turns freely using a screwdriver or something else that you can reach the blades with. If they do not turn easily you may need a new fan motor. If the fan stops, head pressure on the compressor will go up until it trips the High Pressure switch. It will also make the fan work harder so that it gets extremely hot just as you describe. Let me know what you find and we can go from there.
Posted on Aug 23, 2010
  • Brian Niten Aug 25, 2010
    I just realized that you said you have 120 vac on the fan leads. Did you mean 220vac. If you don't have it you need to find out why. Your fan motor may be failing and need to be replaced.
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
The fan still running when the air conditioning stop in auto set mode
fan relay stuck if its on all the time. some use time delay to get the last bit of cooling off indoor coil then shut down
Aug 27, 2013 | Goodman CLJ30AR32 Air Conditioner
A cold start start engine will rin about 5min, than will start running rought and shut down. will not restart till it cools down
possible fuel pump relay.When engine stalls and wont restart listen at fuel tank for fuel pump to buzz for three seconds when key is turned on.
Nov 28, 2010 | 2001 Ford F350 Super Duty SuperCab
My Home Ac Unit Is Not Blowing Any Air
This sounds like the fan not turning during cool. You will have to check the fan relay for power during the cool cycle. The fan relay is run by the low voltage side, but still there is hi voltage present. When in heat the power goes thru the relay on one set of points then in cool goes thru the opposite side. You should have a digram present, and then on the main circuit board there is a code light. Check the light for blinking or (flash) read the bottom of the board for the code ( very small print)
May 17, 2010 | Goodman CKL24AR24 Air Conditioner
My mustang is 1995 and its shuts off and all the gages start jumping up and down and a little box the is on the passengers side bolted to the radiator is buzzing can you tell me what that is and a price...
This is a constant control relay module it controls the pcm , cooling fan, a/c system , fuel pump etc it is a relay center check with your local dealer, and your recycler (junk yard) for pricing
Apr 06, 2010 | 1995 Ford Mustang
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
FAN ON COMPRESSOR SHUTS OFF
The loud buzzing noise if you have heat pump. May be comming from your reversing valve. To quiet this down. Turn off power to outside unit and squirt some oil into the reversing valve coil area. The coil slides onto a shaft this shaft has corroded a liitle and does not let the valve center itself. Alittle oil on the shaft help and quiets this down. DO REMOVE THE COIL WITH THE INSIDE AIR HANDLER POWER ON IF YOU HAVE POWER TO THE THE COIL AND REMOVE IT IT WILL BURN IT UP. yOU CAN JUST UNPLUG THE COIL IF YOU LIKE. RUSS
Jul 18, 2009 | Heating & Cooling
93 camry runs for about 5min than shuts off
check your relays relays can build to much resistance and overheat and they shut down then they cool down and there good till they get hot again
and they dont usually set a check engine light
May 16, 2009 | 1993 Toyota Camry V6
Goodman CKL30AR30 Air Conditioner Logo
154 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
