Question about Epson TM-U220 Matrix Printer
The power light is blinking and not printing anything
    Scholar:
  • 122 Answers
Here's the manual. There could be a possible fix for your problem. Perhaps factory reset instructions.
CLICK HERE!
Hope that helps, give me thumbs up please!
Posted on Aug 23, 2010
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
Hp 3475 light goes on blinking, does not print
Hi
Either of the two problems make the printer blinks-.
check them out.
1. If you have given the printouts and all the pages are not printed then if there are pending printouts remaing in the printer properties the printer will blink continuosly.
2. Any of the 1 cartridge out of 2 may be faulty.
and last option if the printer cover is not closed properly it blinks.
Jul 23, 2010 | HP DeskJet 3745 Printer
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Lower light blinks on everytime I try to print anything and nothing prints
Check for any paper jams, I think the orange light mean that there is a error and therefore cant print, check incartriges and other areas inside
Apr 13, 2009 | HP DeskJet 845c Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
My HP 1100 won't print after power outage during printing
Not worth it to fix. You can find 1100's on ebay for $30.
Mar 02, 2009 | HP LaserJet 1100 Printer
Blinking lights
this means your printer wast pad is full this is now oyu reset your printer but make sure you have put new pads in 1st and dont for get to rate plz
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Sep 11, 2008 | Epson Stylus 2200 InkJet Photo Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Epson TM-U220 Matrix Printer Logo
407 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
