Question about Acer Extensa 5620-4020 Notebook
My acer 5620 laptop boots up with a sharp long sound that goes on for at least more than 3 -4 minutes and stops when the xp sign apprears. Pls tell me how to fix. Solz
    President:
  • 2,291 Answers
There may be error in software loading ,select selective start up , check for sound driver, reinstall sound driver, download reginout and run system scan
Posted on Aug 23, 2010
    Scholar:
  • 122 Answers
Try taking the ram out and giving it a good clean. Then reinsert it. While your at it might as well give your entire laptop a good cleaning, get yourself a can of air.
Hope this helps, give me thumbs up please!
3 Suggested Answers
  • 50 Answers
SOURCE: ACER extensa 5620 drivers
Pls. visit the link http://tinyurl.com/3vs5c2 which will help you to download the driver for the computer.
Posted on Sep 22, 2008
SOURCE: acer extensa 5620 laptop will not boot uo
This happens to many acers eventually...
the one way to completely fix it is to replace the motherboard, until that one breaks not to far in the future.
I recommend getting a new laptop, i had to when i had the exact same problem because i was sick of getting my motherboard fixed. I only had 3 until i gave up on acer.
Posted on Feb 18, 2010
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Passwor bios phoenix trustedcore de acer extensa 5620
pull out the cmos battery as well as the battery, and leave it for 3 minutes. then put the reg. battery back in and boot it up. it should say password disabled. Turn it off and put the cmos battery back in, it should work now. leave positive feedback!
Jan 13, 2011 | Acer Extensa 5620 Notebook PC
I have an acer extensa 4230 which I reformated.I installed the audio,vga and rebooted the system.It rebooted fine.But upon installing a bios system driver,it requested for a reboot.After the system short...
It sounds as though the wrong BIOS has been installed or when downloading the correct BIOS there was a problem with the file and it is corrupt.
Apart from removing the BIOS chip and fitting a programmed one, there is not a lot else you can do except speak to Acer and see if they can help.
Regards.
Oct 20, 2010 | Acer Extensa 5620-4020 Notebook
Acer extensa 5620 p[owers up to boot stops then reboots three times then stops blank screen through out procedure changed hard drive to no effect.?
You boot files could be damaged. Try booting up in Safe mode. To boot in to Safe Mode. Press the F8 key while booting up and you will get a list of booting options. Choose the Safe mode. If you are able to boot up in Safe mode, then the next normal boot should solve the issue.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
Acer extensa 5620 laptop will not boot uo
Then you can check 2 things to see if the machine will boot. If not, then you'll need to get it repaired. FYI, I repair Acers.
Step 1 - remove the battery and the A/C adapter from the back of the computer for about 2 minutes. Replace the battery and the adapter and try to start the machine. If that doesn't work, go to step 2.
Step 2 - Check that the A/C adapter is getting power and the LED for battery charging on the front of the computer lights. You can check the voltage from the power supply with a volt meter, if you have one -- it should read around 18-19 volts. If either of these steps don't work, you'll need to get it looked at.
Problems could be with the power supply, motherboard, power switch, CPU or something else that only time and expertise could properly track down.
Jan 08, 2010 | Acer Extensa 5620-4020 Notebook
To stop acer logo before starting windows xp
Well, Firstly this might be a extreme case but is to reformat your hard drive removing any manufactures partition, and reinstalling the Operating System, but what i would do first is the go to start---run---(type this command and hit enter)"msconfig" the system configuration window should pop up. Go to the boot tab and place check mark in the box which says "No GUI boot" you mat also change the timeout seconds there too. hit apply then OK and reboot your system.
hope this works for you. let met know.
Oct 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Blank screen after boting up
There should be a display toggle key on your keyboard. This will toggle the display from the external display to the laptop lcd. Try pressing the Fn + F5 key to toggle the display.
Jun 10, 2009 | Acer Extensa 5620 Notebook PC
I wanna use 5.1 sound system from my acer extensa 5620 laptop. but still i cant use that. just stereo 2 way out put only i can find. pls solve my problem. thanx Nizar. nyzar63@yahoo.com
Hi there.
If you want to have the full 5.1 surround sound from the laptop you have to purchase external speakers for the laptop.
The laptop itself only produces stereo sound because there are only 2 speakers.
Thanks for choosing FixYa!!
Jun 09, 2009 | Acer Extensa 5620 Notebook PC
Weird whirring, no boot, corrupt recovery partition
IT SOUNDS LIKE THE HARD DRIVE IS GOING ....DO YOU HAVE ANOTHER SYSTEM THAT THIS HARD DRIVE COULD BE CONNECTED TO ? THIS WOULD BE HELPFUL TO UNDERSTAND IF IT'S THE ACTUAL HARD DRIVE GOING OR YOUR FANS. PLEASE ADVISE
Jun 02, 2009 | Acer Extensa 5620 Notebook PC
Sep 22, 2008 | Acer Extensa 5620-6119 Notebook
Acer Extensa 5620-4020 Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
