Question about Garden
Yes, on the pencil torch, it worked great until the butane ran out, I refilled with butane,but I can not get the torch to work again. I sthere a special trick after the butane, maybe a adjustment i don't know about?
  • 4088 Answers
SOURCE: torch is used for jewelry work and is a acetylene
Usually, the blow-out problem is caused by excessive fuel flow at first--too much pressure or valve is opened too far. Once you have a bushy acetylene flame, turn up the air source to bring the flame down to a fuzzy point near the tip end. Brazing and silver soldering work better with just a little less air. My experience is with an oxy-acetylene torch, but results are similar.
Posted on Jul 23, 2009
sonicboomele
  • 1557 Answers
SOURCE: We ran out of ink and we decided to refill the ink
u cant the printer must detect the cartriges are full using calibrated incss. if this does not work as it has not the printer wont work sorry its time to puy in new genuine print carts
Posted on Jun 24, 2010
  • 10865 Answers
SOURCE: The Blazer micro torch does not ignite (no hissing
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Posted on Jul 08, 2010
jakirk
  • 103 Answers
SOURCE: several new torch lighter, filled
adjust the fuel output , it is easiest to do by holding the button down while lighting the flame with a seperate lighter and then setting the flame on the lighter that does not ignite proper, also take into account that the temperature of the lighter by being held in your hand for a while or by being in your pocket can have a great effect on the pressure of the buttane being expelled.
Posted on Jan 21, 2011
kenny_econom
  • 55 Answers
SOURCE: butane leaks out at fill valve of butane micro torch
turn the screw to the right.
Posted on Nov 26, 2012
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
Dec 12, 2015 | Colibri Watches
To refill standard lighters, do i invert the pressurized butane bottle? this seal seems poor either way!
You don't have to, but it usually works better that way. That's assuming the lighter is designed to be refillable.
Jul 10, 2013 | Kitchen Ranges
Butane torch
Could be due to the fine gauze in the nozzle becoming clogged due to maybe not using good quality gas refills?.
May 08, 2013 | Blazer GB2001 Self-Igniting Butane...
The Blazer micro torch does not ignite (no hissing sound for the gas either) and we did fill it with butane? Any suggestions - have had it for awhile - maybe it needs new flint? or whatever ignites it....
Jul 08, 2010 | Omega Blazer Self - Igniting Butane Micro...
Old Victorian Light fixture needs to be repaired. I think soldering the broken parts together would work, but I've never soldered brass parts (only simple electronic motherboards). Anyone out there that...
to solder brass u just use regular solid solder with a tin of acid flux, but u must use a Small butane fueled pin torch or a large high temperature solder iron to do the heating (this really depends on the size of the material being soldered), the brass must be clean and bright, use steel wool for this these small torches are available from any hardware store, they fuel up with butane cartridges used for refilling cigarette lighters
Jan 18, 2010 | Welding Tools
Colibri wellington ligther refilling
Turn the flame height adjuster on the bottom of the lighter to the lowest setting by turning it clockwise.
There are three different kinds of flame height adjusters: hand, thumbnail and screwdriver. If you have a screwdriver flame height adjuster, you will need to use a slotted screwdriver to turn the adjuster.
Hold the lighter away from your face. On the bottom of the lighter there is a refill valve. Push down on the valve with a screwdriver to let the compressed air out. You will know all the air has escaped when you no longer hear a hissing sound.
Turn the lighter upside down, so the flame end is facing the ground. Insert the stem of the clean butane fuel refill at 45 psi pressure into the refill valve and press down.
Hold the refill can in this position for five seconds.
Remove the stem of the refill can from the refill valve, and tap down on the valve once with a screwdriver to force out the remaining air.
Wait three to four minutes to let the gas reach room temperature before attempting to use the lighter again.
Turn the flame adjuster counterclockwise when you are ready to use the lighter again.
good luck
Jan 05, 2018 | Euro-Pro GPS
Dunill lighter - how do I fill it with butane?
  1. Ignore that other load of tosh.
  2. Do not refill your lighter immediately after using it. You should allow enough time for the lighter to cool off.
  3. The flame height adjuster on the bottom of the lighter should be set to minimum by turning CLOCKWISE with a small screw driver. The smaller, usually Phillips head, screw is for dismantling the lighter and should not be touched. The adjusting screw is a larger screw with a standard (slot) head. Some lighters come with a key to turn the adjusting screw. Some models have an adjusting wheel that requires no screwdriver. Please DO NOT FORCE the adjusting screw. If it is hard to turn in one direction this most likely means that the adjustment screw is already at the (-) or (+) limit. Try turning the other direction.
  4. Push the refilling valve with a screwdriver to let out the air inside until no hissing sound is heard. Hold the lighter away from your face. Air inside the fuel tank prevents butane gas from being injected into the tank and causes the lighter to malfunction.
  5. ALWAYS refill the lighter in an upside down position to avoid injecting air into the lighter.
  6. Shake the butane gas refill can, press the stem of the refill can directly onto the refill valve on the bottom of the lighter. Keep them in a straight position and let the gas go into the lighter for about 5 seconds. Repeat for a shorter period if needed.
  7. Allow 3-4 minutes to let gas and lighter components reach room temperature.
  8. Turn the flame adjuster counter clockwise to reach the desired flame height.
  9. Hold the lighter away from your face and body and ignite it carefully. If there is no flame, repeat the refilling process.
  10. If you experience gas leakage with a hissing sound while refilling the lighter, either you are not holding the lighter and gas can in a straight position or the stem of the gas can is not suitable for the lighter. In this case you need to use an adaptor which is usually supplied with the gas can.
  11. Premium butane is required to ensure optimum performance of your lighter. Lighters require the cleanest butane available at a pressure of 45 psi. Recommended using Premium Triple Refined Butane Gas that are packaged in 10-13 oz. cans with a metal fill tip nozzle. Non-premium butane with plastic fill tip nozzles are not recommended as they may cause inconsistent ignition and performance. Impurity of the gas can cause clogging of the burner valve or malfunctioning.
    WARNING: PLEASE, ALWAYS KEEP YOUR LIGHTER AWAY FROM THE REACH OF CHILDREN. USE COMMON SENSE IN HANDLING YOUR LIGHTER.
    Troubleshooting: If you are having problems with your lighter, make sure that:
    You are holding the lighter upside down while refilling. If you did not hold the lighter upside down, there will be air inside the butane tank. You will need to let the air out and try refilling again.
    The flame height is properly adjusted.
    You are not using cheap or incorrect fuel.
    There is no dirt or debris in the lighter. Try blowing forcefully into the top part of the unlit lighter.
Dec 15, 2008 | HHP 12V Cigarette Lighter Adapter (for the...
Garden Logo
171 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
