Question about HP DeskJet 5550 InkJet Printer
HP5550 INKJET PRINTER NEEDS INK CHANGE AND DEVICE TO PLACE THE INK IS NOT MOVING TO THE CENTER.
    Scholar:
  • 122 Answers
Just open the top of the printer and manually grab the device and move it to the center. Then take out the ink and place the new ink in. Remember to take the protective strip off the new ink.
Hope this helps, give me thumbs up please.
Posted on Aug 23, 2010
Did not use for 2 years, need to change ink cartredges, but cant remember how, need help.
To change the ink cartridge on a Canon MP250 you will first need to turn on the printer. When the ink stops moving in the center position you can than flip open the tab. You then can pop out the ink depending on which one you need to replace.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon PIXMA MP240 All-In-One InkJet...
DeskJet 460. Opening ink cart cover does not make cartridges slew to centre.
Hi
This is a problem with the ink cartridge. Maybe your cartridge is bad and needs to be replaced. But because the carriage is not moving you can turn off the printer and try to move it with hand it should move now. Once out of place try to remove both the cartridges and turn on the printer. Now when it says error then open the cover and the carriage will move to center and you can install the cartridges back in the printer and try.
RATE MY SOLUTION
Jul 06, 2011 | HP Deskjet 460c InkJet Printer
HP5550. Color ink ran out. Replaced with refilled cartridge, ink light still flashing. If I use an original cartridge this does not happen. Shop tells me cartidges are fine and proved it
some HP printers do this after a non original cartridge used The printer should still be able to operate even with the light flashing. If this does not work you may require to replace the print head.
Mar 21, 2011 | HP DeskJet 5550 InkJet Printer
I want know that about kolkata Hp5550 deskjet printer reparing center ?
http://h10025.www1.hp.com/ewfrf/wc/product?product=71896&lc=en&cc=us&dlc=en&lang=en&cc=us
I would check with hp.com for repair center information.
Otherwise, there is a wealth of information on the deskjet 5550 inkjet printer at the above site.
Dec 31, 2010 | HP DeskJet 5550 InkJet Printer
HP5550 printer is printing everything in green. We have true HP cartridges
So, your "blue" and "yellow" ink-cartridges are OK, and are mixing to produce "green".
But, either your "red" ink-cartridge is empty, or the ink-jets that shoot that colour onto the paper are BLOCKED.
Run a print-head-cleaning-cycle, using the HP Support Tools that were installed from the HP CD-ROM, and then, if necessary, replace/refill the "red" cartridge.
Aug 30, 2010 | HP DeskJet 5550 InkJet Printer
How to chang ink
When it is time to replace an ink cartridge in your HP inkjet printer, you will receive a pop up message on your computer screen. Replacing an ink cartridge is just part of owning an inkjet printer, and a tradeoff with the high quality imaging you are able to achieve on an HP inkjet. It is not something a professional needs to do; just follow these simple instructions to complete the change and get right back to printing.
  1. Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
  2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
  3. Press the change cartridge button. It is at the top of the printer next to the power button.
  4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
  5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
  6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
  7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Good luck.
Apr 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Carraige head is locked in place on my kodak easy share 5500
go to www.kodak.com/go/itg. Choose All-in-one printer - Cannot replace ink (printhead not moving to center position) and follow the step by step solution.
Mar 05, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Kodak 5300 aio change inks
When you turn the printer off and back on you should hear a noise, when you lift the lid the cartridges moving to the center so you can replace them.
Jan 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP DeskJet 5550 InkJet Printer Logo
Seeker5211
Seeker5211
