Question about Mitsubishi VS-60601 60" Rear Projection Television
1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
I have a 1998 Mitsubishi vs-60601. The picture has in the past been very good considering the technology. The picture has been becoming increasingly less vibrant, however all of the functions work properly. Is there a possible componant that could be replaced, to bring the picture back to life? Any help would be appreciated. Thanks, Tom.
    Sergeant:
  • 395 Answers
The first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
Posted on May 04, 2008
  • Mitsubishi Master
  • 8,617 Answers
The two things you can do is 1. polish the mirror and CRT lenses as they get dull over time. Do not use windex on the mirror just a soft damp cloth then dry. 2. Change the coolant in the CRTs as this can get cloudy over time causeing the CRTs to loose their sharpness and brilliance.
Mitsubishi wd-52327
Its more likely that the front and rear mirrors need to be cleaned. The mirrors tend t get dull and that will cause the picture to become dull and the colors wont appear as vibrant as normal.
Mar 26, 2013 | Mitsubishi WD-52525 52" Rear Projection...
The tv turns on but there is no picture. just an audio thump thump. like a drum. any ideas
Look inside front panel. Look under right side picture tube for oil leakage on signal board. If you see a puddle and possibly corrosion, then the tv is toast.
Jan 17, 2011 | Mitsubishi VS-60601 60" Rear Projection...
Where is the Convergence IC on my Mitsubishi VS-60601 1997 Serial #104094. You told me what the problem was with my TV and showed me what a Convergence IC looks like, but now that the projector TV is...
Convergence IC will be mounted on a big Aluinuim Heat Sink They are Big Black ICs and will have Parts # on Them example STK392-570 There is 2 of them together.
Mats Electronics has them 1-800-628-1118
Nov 04, 2010 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60601 has a distorted picture with double vision even if it's a DVD playing. The sides of the screen get narrower in the center of the sides when it's turned on. I'm mechanically inclined and...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 19, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60601 60 in.
I just encountered the same problem. What was your solution?
Sep 12, 2008 | Mitsubishi VS-60601 60" Rear Projection...
VS60601 Picture yesterday, none today
That model will usually leak coolant directly onto the vertical output area and that will put the tubes into protective blanking and you will have sound but no picture.
Aug 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
VS-60601 Mitsubishi Problem...
That model is famous for the CRts leaking onto the chassis which causes all kinds of problems and can cause the main circuit board to short as well as destroy the solder. Try looking at the board for evidence of a pastey substance that would indicate CRT coolant leakage. Let me know what you find.
Oct 24, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS 60601 picture
You need to change the convergence IC's my friend. If you know how to solder and work on printed circuit boards, this is an easy repair, BUT if you have no experience, play it safe and let a pro do this repair for you. Good Luck
Aug 11, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
