Question about Intel Computers & Internet
WHEN I INSTALL SERVER 2003 AND ERROR MESSAGE NTLDR IS MISSING PLZ RESOLVE THIS ERROR
    Sergeant:
    Champion:
  • 390 Answers
Http://kb.acronis.com/content/1759.
try this solution there
Posted on Sep 02, 2010
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Naamy hp proLiant in giving the message that NTLDR is missing what it is the problem?
To repair missing NTLDR orcorrupted system file/s, boot up with the Windows installation CD then - Press R to repair wheninstructed. Press 1 or Enter to repairthe C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process willtake quite a long time.
Jun 10, 2011 | HP ProLiant ML110 Server
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
Recovery on presario 1692 NTLDR is not responding
Plz check the below link from HP. It will help you in resolving the issue. ?Missing NTLDR? Serious Error Message Appears During Startup http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00213449&cc=us&lc=en&dlc=en Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | Compaq Presario 1692 Notebook
Dell 100l ntdrl missing on start up
For some reason your boot files are missing.
ntldr ( NT loader ) is one of the main boot files that is missing.
possibly a boot sector virus.which corrupts the ntldr file.
Put the disc back in, and you can choose to either install the O/S, or you can repair the current O/S, go for the repair,
Should resolve the problem,
Then run a full system vius scan,
Should be good then
Regards
Richard.
Apr 20, 2009 | Dell Latitude 100L Notebook
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
