Question about ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM (Combo) Burner
Where do I find a belt for my Raymedia Model RL-A700 DVD drawer drive?
The DVD drawer will not open unless a disc is in the drive. When the drawer would not open I took the cover off the player. The DRC8295N is a VCR-DVD/R RW player recorder. The DVD drive will record on...
The problem isn't with the motor being too weak, but the belt which the motor drives. I had the EXACT problem just as you described. What I did was I took off the belt and cleaned it with rubbing alcohol because apparently the belt picked up some of the grease from the gears and wouldn't rotate when the motor spinned. This belt actually pulls down the mechanism, on which the CD sits, from the magnet. So, just clean the belt and you should be good to go. If the belt is very loose, you might need to replace it.
Feb 14, 2011 | RCA DRC8295N DVD Recorder/VCR
My x box will not open to put a game in the consule what is wrong with my system
The dvd drives on these can be a problem, You could have a small belt in the drawer mechanism faulty. It means removing it out to check , if you replace the dvd drive though you must swap over the circuit board in the dvd drive your dvd drive because it is (keyed to the motherboard). The drawer runners could be sticking also, in need of some light oil.
Hope this helps
pete
Nov 06, 2010 | Microsoft Xbox 360 Console
My writemaster dvd rw is failing to release thye drawer. is there a belt or drive i can repair?
you can at least get the drawer open and take out the disc by 1) detach power 2) straighten a paperclip and push it through the small hole just above the green indicator lamp below the drawer. If you figure out the next step pls tell me!
Oct 03, 2010 | Samsung Super-WriteMaster SE-S164L DVD?RW...
I have a Kenwood mini hifi system XD-A700 i cannot open the CD player drawer to play cds.I dont have an instruction manual.
You can download the manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/xd951.pdf
Aug 29, 2010 | Kenwood XD-A700 Shelf System
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD drawer won't open - there is not a dvd inside.Last night I played a dvd successfully. It did not have a label on it on anything that could result in something getting stuck.
In my expertise the smallest issue from an out of allignment issue with the drawer to a faulty spindle motor that spins t oo fast. The best bet and what i would do is either remove the drive and make sure everything is sliding ok, and if no obvious fault can be found(loose belt slipping gear etc) i would replace the dvd drive of the unit. Good Luck.
Sep 24, 2009 | Televison & Video
CD Rom drawers do not open or close, drive belts have popped out
Unfortunatly, these belts are not availible for consumer purchase and, most service centers will just replace the entire device. i have used regular rubber bands that are identical in size to run many rom drives. this method seems to work just fine.
Its very unfortunate when these original belts break and, there is no replacment belt on the market. the only option is to purchae a store bought rubber band that matches the same size as the broken original band. this will work.
Jun 10, 2009 | Dell Dimension 8400 PC Desktop
ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM (Combo) Burner Logo
187 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
