Question about Garden
My Victa 2/stroke lawn mower is difficult to start and only runs fo 20or 30 seconds.It seems to starve for fuel but I have cleand the tank and lines. the spark is good.
2 Suggested Answers
  • 129 Answers
SOURCE: my Victa 2/stroke is difficult
Test pls delete
Posted on Aug 23, 2010
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
Engine starts. Why does it only run a few minutes, then stop?
a few things may cause this. it sounds like it is starving for fuel. the spark plug may be breaking down when it gets hot. try a new spark plug. if the fuel and fuel lines are in bad shape, old, soft or hard. the fuel don't smell right. fuel filter plugged up. the carburetor may need to be cleaned and a rebuild kit as they are cheap. if it is 30 years old. be sure the fuel lines, filter and carburetor are in good shape. hope this gives you an idea on where to start. good luck
Mar 14, 2016 | Garden
Victa.two.stroke.wont.start
www.victa.com/au/support-centre/owner-guides
check spark.
If ok. chec for fuel inside on plug. If ok
check compression of engine.
Oct 12, 2014 | Garden
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
Victa 2 stroke starts OK then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Oct 07, 2009 | Garden
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
