Question about Dell Inspiron XPS M140 Notebook
USB ports all 4 of my USB ports don't work anymore. is there anyway to fix this or do i have to get everything replaced? and if so, where can i do that?
  • 655 Answers
I think there is no need to replace any thing:
  • First check out if the drivers for USB hub properly installed. To check out you should go Device manager and see if there is any component with yellow mark. If yes then re-install driver it will fix your problem.
If above does not fix your problem, then let me know:
  • How you made test and come to know that USB ports or not working?
  • Which OS you are using?
Thanks
Iqbal
Posted on May 04, 2008
Ok. hello. my name is James. i am a student in high-school. and I'm having problems with my computer. Since i got my computer everything has been working great and i haven't had any problems, however, for...
Try this fix, turn off your computer properly then unplug the computer from the wall socket, then press the power button and hold for about 3-5 seconds. Then plug your computer back in, restart the computer then wait for the boot to settle into Windows.
After doing those things plug in a USB device into the same port as you have been doing. It should work now, if it does not plug it into another port if it does not go to all of the ports and try them all if none of them work then you cable may have come loose on your board or it is a bad USB HUB on your computer it is obvious it is not the unit if it worked on another computer.
You will have to replace it or if it works on one of them then change out the bad one. Replace it! Or go and get a 4 port USB extension using just one of the USB ports. So that you will have more ports without the fix. Replace any worn parts or devices that do not work anymore. John
Jan 22, 2011 | Computers & Internet
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
My mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 31, 2009 | Western Digital My Book Essential 500GB...
Broken Headphone Jack
Replacing it is expensive. However the player is bound to have some sort of usb port on it. You can buy some usb headphones for about £15 and use those.
Jul 07, 2009 | Centon Electronics MP4-001 MP3 Player
My dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Apr 06, 2009 | Dynex 4-Port USB 2.0 Hub
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
PC Chips M957G MB. Can the 4 rear 4 USB ports easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
The 4 USB Ports in the rear stopped working. Can they easily be replaced?
hi there,
Thank you
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
Computer will not recognise camera.
hey,
have you tryed to plug camera into another computer, maybe a windows?
have you tryed to use another usb cable?
also connector in camera can have bad soldering
check this movie
hope this help you get closer to solution
;) /michael
why pay when you can play
Dec 19, 2007 | Cameras
Dell Inspiron XPS M140 Notebook Logo
93 people viewed this question
Alun Cox
