Question about Startrac Fitness Products Star Trac E-Series Treadmill with Integrated Screen
What does elevation stall means - Startrac Fitness Products Star Trac E-Series Treadmill with Integrated Screen
Kodak I1X09 fault code
I1X09 One Line Description: INSERTER SUPPLY 3 stalled when it was moving down Error Type: Soft Shutdown Error Description: If the ELEVATOR STEPPER MOTOR uses more than 130% of the maximum number of steps to move the PLATFORM of INSERTER SUPPLY 3 down to the expected position, the INSERTER SUPPLY CONTROL BOARD determines that the PLATFORM has stalled. An I1X09 error code is recorded in the error table and you must either use another INSERTER SUPPLY or press OK on the OCI to clear it. Theory guide: I1INSER1 Possible Causes:
1 The input to LOGIC and CONTROL from the DOWN LIMIT SWITCH is not correct. 2 The input to LOGIC and CONTROL from the PAPER FED SENSOR is not correct. 3 Mechanical binds in the ELEVATOR DRIVE SYSTEM 4 The input to LOGIC and CONTROL is not correct. 5 The FLAT CABLE is damaged. 6 Circuit for the ELEVATOR STEPPER MOTOR is not operating.
Nov 20, 2013 | Kodak Digimaster Ex110, Same As Canon Ir...
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
2002 Malibu stalls while driving, doesn't over heat. But can start smelling gas fumes before it stalls. usually wait about 5 mins then restarts. in higher elevation runs fine but in lower elevatio
It sounds like the catalytic converter could possibly be almost completely plugged up not allowing the exhaust to leave the engine like it should. It just builds up in the cylinder head and when it gets too much in it built up and there's no where to go, it'll stall the engine. By letting it sit for a few minutes, it gives the exhaust time to find a way out and the car will restart.
Mar 27, 2013 | Chevrolet Malibu Cars & Trucks
E 7 error
1) this means 2 alternatives.
2)Alternative:
God bless you
Nov 07, 2012 | Exercise & Fitness
What means error 07 by HAMMER walkrunner? how can i resolve that?
means 2 options:God bless you
ERROR CODE # 7
2)Alternative:
Oct 08, 2012 | Hammer Walkrunner Rpe Treadmill
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
Message ELSTL what does it mean
This means the elevation has stalled. Please see the EL STL Flow Chart in the service manual starting on page 68.
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20TR4500.pdf
Aug 11, 2012 | Startrac Fitness Products Star Trac 4500...
My Chevrolet S10 1996 currently problem is when I ride up in elevation the truck stalls. Also, coming down in elevation it drives fine but when I come to a stop it stalls. Could this be a Coil wire?
Sounds more like a fuel / air problem. What is the condition of your O2 sensors? They could be reading incorrectly and causing a lean or rich condition.
Sep 07, 2010 | 1996 Chevrolet S-10 Pickup
Startrac Fitness Products Star Trac E-Series Treadmill with Integrated Screen Logo
581 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Tim Loy
Level 1 Expert
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
