Recendly, my humidifier had frosted and I concluded that the room temperature was too low. I let it thaw, and decided to take the opportunity to clean the inside. There was a lot of dust on the humidity probe, and I opened the tiny white plastic cage in which the probe rests to make a good job. On the cage, I noticed the number 16 written by hand on it. When I reassembled everything, the humidity readings were way off and still are. I thought that there might be some setting knob to calibrate the humidity probe, but found none.
I certainly did something wrong, but now what can I do to?
Running a dehumidifier when the ambient temperature is to low will cause freeze-ups. Also running it when the dew point of the moisture in the air is to low will cause it to freeze up when you set it to low which would be a higher number on the set point.
The hand written number on the probe casing is probably a quality control inspector number.
I am replacing the motor capacitor with a new one There is a red wire and two others, what is the...
(More)(More)
I am replacing the motor capacitor with a new one There is a red wire and two others, what is the correct hook up for the wires on the capacitor? Where does red go etc...
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
The dehumidifier runs and sounds like the compressor is running but does hot fill with water even...
(More)(More)
The dehumidifier runs and sounds like the compressor is running but does hot fill with water even thou the reading shows there is 85% moisture in the air.
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
