Question about Dell UltraSharp 2007WFP Monitor
I have 2 windows on my screen side by side one has side I could browse and and the other is in all blue and has a note that says No Composite inputs signal. On the button part of the screen nest to on and off button are the menu buttons and niether of them work and besides that there are 4 numbers 1 to 4 and the numbers 1 and 4 are in green.
  • 724 Answers
Get into the display console and look for the monitor split screen settings
Posted on Aug 23, 2010
How to connect composite and component
Your description is somewhat confusing. Most TVs today have component inputs with limited composite inputs. If you have the red green and blue video input Jacks, that is component. The single Yellow Jack is composite. There are adapters available on the internet. You don't need audio in the adapter because audio out to audio in from DVD to TV is the same regardless of the video input. Another option if your DVD is the single yellow output is to convert that to HDMI for which adapters are available. Hear you do have to use the audio jacks to the converter for the HDMI cable to function. Otherwise more information is necessary.
Jan 02, 2018 | Televison & Video
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Have connected dvd/vcr but the tv screen is blue. Can you help please.
You MUST select EXTERNAL Input, NOT a Channel. You MUST connect up via, the INPUTS at rear, either COMPONENT, or COMPOSITE, Or, HDMI. Except for HDMI, ALL Cables, go Color Jack, to Color jack. 3 for composite & Audio, and 5 for Component & Audio.
Apr 23, 2010 | Sanyo DVW-7200 DVD/VCR
Connection using Component video No Video
1-Locate the audio/video input jacks AND the component input jacks on the TV.
Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
Look for inputs marked Audio and Video IN.
Do NOT connect the system to anything marked OUT.
2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
http://bit.ly/2ykOBno
Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
The dr-mv100b only plays in black and white?
You may want to make sure your connections are correct. You will typically see this when you hook up composite connections into component inputs or vice versa.
Make sure if using composite (Red,White, Yellow) cables that they are hooked up to the composite out put jack on rear panel of the unit.*Note: composite out put jack is located directly below the composite 'Input 1' jack with a black 'background' on this recorder.So don't confuse this 'output' with an 'input' simply because it is below the 'input' jack.
Also make sure you are hooking up into composite inputs and not component (Green,Blue,Red) jacks.
Oct 31, 2009 | JVC DR-MV100B DVD Recorder/VCR
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No sound when using xbox
Assuming you are using the Red, Green & Blue Component inputs from the X-Box, there will be either a set of Red & White phono (RCA) inputs for EXT3 audio, or a standard 3.5mm jack socket. If so, use these. You will need an adaptor if it is a jack socket.
Dependant on model, the setup menu should have options to assign the audio input to the correct video source.
The side inputs are separate, and are only for the composite or S-video inputs.
NOTE: if you are using the component inputs, you don't connect the yellow composite input.
If this doesn't help, post the exact model number and I will be able to advise you further.
Apr 19, 2009 | Televison & Video
No composite input signal
Try the following:
Right after power on, tap the F8 key to see if you can get a short menu to come up.
If it does, select "Safe Mode."
If your screen looks different, it may be just the driver for the display card or monitor is trashed (Windows like doing that, keeps us challenged).
- Open Control Panel, then System, then Hardware, finally Device Manager.
- Locate Display adaptors, open and delete the adaptor listed (all, if more than one.)     - Locate Monitors, open, delete any listing there.
Reboot.
Windows should 'find' two 'new' devices and install the drivers for them.
The display may still be different if you had other than the default settings.
Go then to the Display folder of the Control Panel, click on 'Settings' and experiment. Depending on your Windows version, if you choose something dumb so it makes the screen unreadable, ignore it and Win will ask if you want to keep it and give you some time to acknowledge that you like it. When you don't, it will just go back to the pre-tinkering settings.
Apr 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 2007WFP Monitor Logo
102 people viewed this question
Alun Cox
