Question about Saeco VIA Venezia
Why does water not come through porta filter?
  • Saeco Master
  • 1,711 Answers
Posted on Aug 23, 2010
2 Suggested Answers
  • 18 Answers
SOURCE: I descaled my machine and then cleaned the porta
If what you are calling the portafilter is actually the shower filter,( portafilter is what you put the coffee in, shower filter is the one in the group head which is held in by a single screw) then when that second screw fell out it sounds like one or two other things may have fallen out also. To stop water/ steam leaking out the boiler, a small rubber seal and spring seat up in the hole where the water comes out. You need to find them or get new items and fit them to the machine. If not sure, get a parts diagram and you will see what I mean. They are easy to replace.
Posted on Dec 15, 2010
Need fuel filter for a porta heat 100
hi Herb.
there is a lot of places you could get one from.but i think it best you go to this link and see what helps you best.
i have had a look on ebay and there is some on there.
fuel filter for porta heat 100 Google Search
Nov 21, 2017 | Cars & Trucks
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
How do I fix the water pump of a delonghi BC4264B? It's not pumping any water to make espresso. the machine heats up well, the steamer works fine, the drip brew side works fine. I'm not getting any...
Is there any water coming out of the group head when the porta filter is not used???the group head has a filter on it and it could be totally clogged
Jun 11, 2014 | DeLonghi DE500P Dehumidifier
Delonghi icona porta filter too tight to turn
Hi mate, had the same problem and fixed it this way. get a tiny drop of olive or almond oil on your finger and run it round edge of the pod in the holder, works a treat
Nov 18, 2012 | Coffee Makers & Espresso Machines
Cuisinart espresso maker
One question: have you tried the machine without the porta-filter attached? If it works through an entire cycle without the porta-filter attached, then the porta-filter is clogged. I've lost that special little tool to poke into the hole on the porta-filter, but a fine-tipped needle works just as well. Other pins that I've tried are too thick. Sometimes there's a piece of coffee that has made it through the top part of the filter gets stuck at the single hole that is the exit. Find an appropriate pin and poke around with it, then run WATER only through the filter. If it makes it through a cycle, you've fixed it. This clogging can happen very frequently with too finely ground coffee.
If however, your machine stops and beeps without a filter attached, then there's something restricting the flow inside the machine and your only alternative is vinegar, or similar decalcifier.
May 05, 2012 | Cuisinart EM-200 Espresso Machine
I descaled my machine and then cleaned the porta filter. When I remived the portat filter another internal screw came out. When I put them both back in tight I get water or steam leaking out of the porta...
Dec 15, 2010 | Saeco VIA Venezia
Water pours out from all around when making coffee. I fill the filter with coffee and turn the machine to brew and water seems to overfill and comes out over the top.
Theres a seal from the machine to the handle or porta filter its acalled a group seal it is worn or dried up solution is to replace the seal
Dec 16, 2009 | Breville ESP8XL Espresso Machine
Water is dripping out the side of the porta filter
You will have to replace the group gasket, you can also try using a group brush to clean any coffee grounds up there, but you will most likely have to replace the group gasket.
Apr 06, 2009 | Gaggia Evolution Espresso Machine
Saeco VIA Venezia Logo
1,034 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
