What setting should i have my fridge and freezer set to
  • tellyho Feb 04, 2009
    my ducted air conditon does not work properly when it's turned on it runs alright but the air is not cooling enough even if you set the temperature at 16C it is a panasoni airconditioner 380-415v. that is all the information i have on the model outside the house . we moved in 4 years ago and it was working perfectly. sometimes we have to turn it off because it was too cold for us.i hope anyone out there c an help me before i call any technician thank you.
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
What temp should freezer be set
One of the most basic ways to ensure food safety in your kitchen is to set your refrigerator and freezer to safe temperatures for food storage. According to the Food and **** Administration, your fridge should be set at or below 40 F (4 C). Your freezer should be set at 0 F (-18 C).9 Jan 2014
At what temperatures should your fridge and freezer be set? - Jsonline
archive.jsonline.com/.../at-what-temperatures-should-your-fridge-and-freezer-be-set-b99.
Nov 18, 2016 | Refrigerators
Bush fridge freezer need coldest setting for fridge 1_7
freezers settings are the larger the number the colder the freezer as against fridge settings where the smaller the number the colder the fridge
Aug 29, 2016 | Bush Refrigerators
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
Sep 22, 2010 | Samsung RB215LASH
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Jan 03, 2018 | Samsung RS2630SH Side by Side Refrigerator
How to set the thermostat? gaggenau fridge freezer
how to set thermostat on double door fridge freezer
Nov 24, 2008 | Gaggenau Refrigerators
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
