Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My external hard disc all the folders change ikb shortcut folder
SOURCE: My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive
I believe this is a trojan. I have the same problem. I found by going into Properties-shortcut tab- you have to rename the shortcut to the correct shortcut. You should notice some wierd file name like "keuiku.scr." Simply rename it to the original name and it works for me.
Posted on Aug 01, 2010
  • 212 Answers
SOURCE: My pc cannot detect my
It could be a few things.....First, your drive could be going bad....it could maybe even just have a power problem.
I would try a few things to troubleshoot this.
  • Check your power. Make sure the cords are plugged in tightly on either end. If it is plugged into a power strip, maybe try another strip, or wall outlet. Make sure any power strip is also switched on. If Windows is having trouble detecting it, it may not be seeing it as a powered device.
  • Try another USB port. Sometimes Windows can have trouble installing a driver.....on occasion swapping the port can help. or you could have a USB port not working properly.
  • with the drive powered on put your ear up to it and listen for any strange sounds. Clicking and grinding that are not they typical sounds you hear from a drive could indicate that the drive is dying. (Drives generally make some random sounds as it is accessing data and the whirring sound of the platters spinning.....but a rhythmic or constant click would be a bad thing...or some grinding sounds as well) If you think your drive is going bad, it's best to get the data copied elsewhere off of it if you get a "last chance"
  • if the drive is dying, I have heard of some people putting the drive in the freezer, or even giving it a whack with a screwdriver (if the drive arm is stuck, this could unstick it...but really I wouldnt recommend it unless you have exhausted every possible option)
  • If you think it is a power problem, you could buy a USB Drive adapter like this one: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554&CatId=3770 (You can get them much cheaper on eBay actually) With this device you can remove the actual drive from the enclosure, and try hooking it up directly using the drive adapter (The enclosure has the power supply to the drive, so if you have a power problem, using the drive adapter may take that out of the mix)
  • If you get one shot....copy the data off of it just in case....and make sure you have backups in the future to try and avoid problems like this.
Good Luck
Posted on May 12, 2011
SOURCE: I HAD Western Digital My
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
Posted on May 24, 2011
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
Posted on Dec 07, 2011
  • 30 Answers
It sounds like your hard drive is virus infected. Have you tried to scan this drive with your computer antivirus tool?
You should always be careful when you decide to separate/delete some suspicious files.
Or you prefer to firstly use a hard drive data recovery freeware that could deeply scan your computer and recover back all your needed data back:
http://www.freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
Remember to back up everything important on different drives next time.
Posted on Aug 28, 2013
My external hard disk has been infested with viruses and files and folders made shortcuts. how can i recover the files and folders?
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - http://www.shortcutvirusremover.com
Place it in your pen drive and double click to run. Press Enter to confirm its process. That is all. Shortcuts will remove and your data will be back in a second.
Mar 05, 2014 | Computers & Internet
ALL FOLDERS ON MY USB HAVE BEEN CHANGED TO SHORT CUTS
This is usually a signal that a virus is at work. Check that your computer has been checked and is clear. Then check your thumb drives-all of them including your external hard drives.
Apr 15, 2013 | Dane-Elec DaneElec 4GB USB Drive Red Hard...
I have a Transcend StoreJet 25M 500G external, I have a problem because when I plug it to the computer it will just display a shortcut icon, I can't access anymore my folders saved. This happen wh
the attributes of your files and folders have changed, go to folder option, then click show hidden files, also uncheck show system protected files,..........download some attribute changes software for changing the attributes
Feb 04, 2013 | Computers & Internet
I have S2 portable 640gb external hard drive. Do not open the main folder with info and gives me only shortcuts and no way to my folders
Do you think my problem is a cable wear or the device itself
and how can get access to my data
can anyone hepl me
please
May 05, 2012 | Samsung S2 Portable 640 GB USB 30 External...
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
May 18, 2011 | Western Digital My Book Essential 1TB...
My SmartDisk FireLite external hard drive is showing 33 GB free out of 55 GB. I had all of my and my wife's files stored on it, but now it only shows all of our folders as shortcuts and says the item the...
I believe some virus caught your computer. If you can't find you're files try this.
-Go to that hard disk.
-In the menu bar look for tools.
-Folder option
-In the folder option window click view
-look for hidden files and folders
-In the 2 radio buttons click show hidden files and folders
-click apply.
If this is correct there is a way to remove those hidden things.
-Select the file or folder you wish to not hide.
-right click and look for properties
-unchecked hidden files and apply
hope this helps. Thank you for using Fixya!
Apr 19, 2011 | SmartDisk FireLite 80 GB Hard Drive
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive, it seems like memory in my HD is used, but when i click in to open folder it says that file cannot find :(
Well, it's obviously your external WD drive infected with virus which stop you from accessing the data by turning them into shortcuts (such as 1KB or 2KB). This blog article how to fix folder become shortcuts should help you out. Follow the step by step please. Note: do not attempt to format the drive before you try.
Aug 18, 2010 | Western Digital My Book Essential Edition...
What do I have to do to start copying file to the external hard drive. Looks like I am just getting shortcuts. The file folders have the small black arrow indicating a shortcut
Hi right click on the file you want to put on the ext. hard drive. You will see a option "send to" click that then choose the ext hard drive. This will sent the whole file and not just a shortcut. Thank you for using Fixya.com
Feb 11, 2010 | Computers & Internet
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
