Question about Dishwashers
Bosch SHX 46L Our dishwasher would complete a cycle everything good. Sometime after, it would spray and wet the dishes leaving water in the bottem of the washer. Now, the pump runs constantly when the washer is powered on and it will not start a wash cycle. Any ideas?
  • brian johnson Aug 24, 2010
    Presentlly, our dish washer will not start a cycle. When the power button is pushed to on the drain pump runs continuosly. The washer will not do anything else. I poured a picture of water into it and it did pump it out. It did not stop and it will not start a cleaning cycle.
  • 12,061 Answers
Http://www.computercrowd.com/Itm250480379703_60270_Bosch_Dishwasher_Service_Repair_Manual.aspx
http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=196179&&model_id=232418#d196179
It sounds to me as if your controller has been spiked? This would then explain this very odd behavior.
Above please find your servicing data.
http://forum.appliancepartspros.com/attachments/dishwasher-repair/1402d1257882624-bosch-dishwasher-troubleshoot-manual-how-replace-control-module.doc
Above is a How to replace your controller, link, copy.pste to the search bar.
Also have a look at this forum, it deals with your issue, and there are many helpful tips, this is page 8, please go back, and start at one, if this particular page isn't too much help.
http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual-8.html
Posted on Aug 24, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
  • Rylee Smith
    Rylee Smith Aug 24, 2010
    If it wont start a cycle the first thing that should be checked is the drain pump and motor, if they are fine then it is the control that has gone bad and should be replaced.
Bosch dishwasher won't drain and leaves film
You may have to use a rinse aid to get good results.
Jan 30, 2017 | Bosch Dishwashers
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Leaves residue on dishes
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 21, 2011 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dear Sirs, I have a client with a Bosch dishwasher that is leaving a film on all of the dishes. the water valve is working and the drain pump is working. Apparently this has just started. Any ideas?...
Hello
Welcome to FixYa.
Can you provide a model number of your Bosch dishwasher ?
Depending on the model ( i.e. SHU, SHV, SHE, SHX followed by several caricatures etc. ) it can be several possibilities so I`ll hold off generalizing and instead try and speak specific about your model.
Regards,
Macmarkus :)
Sep 23, 2010 | Bosch Dishwashers
How do you get the washer to dry dishes? What
Check the operators' manual.Don't use the drying element as it's costly on the electric bill.When the washing cycle is complete leave the door partially open and let the water evaporate
Sep 28, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
300 people viewed this question
Top Dishwashers Experts
Owen Barnes
