Question about Sony KDS-R60XBR1 60" Projection HDTV
Kds-r6oxbr1 Did cleaning the fan eliminate the 4 flashing red lights and if not, did the solution wind up being the lamp? We are going to attempt your advice on cleaning the fans. Does Sony acknowledge this as a manufacturer's problem and are they offering any compensation like with the Optic Block?
  • garg55 May 13, 2008
    Have had the same problem with the Sony KDS-R50XBR1 50 in. Used compressed air several times on the fan through the grids. It will usually last a day or two and then the same problem occurs.
After Talking to a Sony Tech, I have learned that the three blinking lights is a problem with the contact for the lamp door. The four blinking lights is a problem with one of four fans which is usually the lamp fan that everyone has to spray with compressed air. Sony with not cover any of these problems under the extended warranty for the optical block problem. So I guess we will have to keep spraying with air, but sooner or later the fan will stop completely and that will cost about 4 to 5 hundred dollars to have fixed.
Posted on May 22, 2008
  • 4 Answers
I had the greenish tint problem and the service technician came out and replced the optical box for free under the sony extended warrantee. The technician exlained that the optical box design gets too hot and destroys teh first LCD screen nearest the bulb (green). The new optical blocks have a filter lense placed in front of the green LCD screen to try to cut back some of the heat so it doesn't happen again.  After he left, we started getting the intermittent porblem of the set shuttng down after 2 seconds of picture and the red light flashies four times.  For a few weeks, it would eventally come back on if tried a few more times, but last week it just wouldn't comeon anymore.  I called the technician and he said that the sets that had the optical box problem, oftern had this problem because the excess heat warped the door on the light. there is a little plastic pin on the door near the screw that goes into a whole in the set and triggers a micro switch, which is intended to make sure the light doesn't comeon if the door is not completely closed. When the door warps just a ittle, the pin does not engage the micro-switch enough and the set thinks the door is not installed.  I opened the door and closed it again, making sure it was firmly seated and teh screw was tight.  the set started right up like normal.  He said he has ordered a new door and will drop by and put it on when it comes in.....also complete;ly covered by the Sony extended warrantee for teh optical box problem.  Hope this helps.  The set has a better picture than any other projection TV I have seen....when it works. I am still glad I bought a Sony because they have stepped up and taken responsibility for this obvious design flaw on a $4K TV.  What amazed me is all the postings I read where people have no idea why this is happening. My technicain said he changes a couple of optical blocks a week and knew immediately that the warped door was the four red light problem. He has changed so many, that he said his first time it took almost 3 hours ( all the guts of the set have to come out to get the optical box out...not something i would recommend for the amateur), but now he does it in 45 minutes.....which I witnessed. He also took the time to vacuum out allthe inside of the set when he had it all apart. Loquatius
Posted on May 21, 2008
  • Loquatius May 21, 2008
    p.s.  did I mention that I bought my set at Tweeters, Dec 2005, without the extended warrantee ? None of this has cost me a dime. Sony covered it all.  By the way, my bulb died fater I had the set 18 months. Tweeters said they could order me one and it would take a week or so.  I called the Sears national repair center and they sent me one overnight for $250 (same price as Tweeters) and I installed it in less than 3 minutes. However, when the techician came out to replace the optical box, he mentioed that there are three intensity setting on the set (normal, professonal, vivid )  He said that many of the delivery guys set it up initially on "vivid" because this is the brightest and looks best, expecially during the day. The problem is that the extra brightness not only burns out the bulb signifiicantly faster, it also adds significantly to the overheating problem with the optical box, fans and door warping.  I leave it on normal,now.  If I am watching an afternoon ballgame, I will close the curtaines in the room instead of kicking up the intensity of the lamp......and save both the lamp life and the new optical box !!! ....and teh plastic door :-)
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
Television wont turn on. green light flashes 7x and then flashes red 4x
check and see if the fans are all running, a 4 blink code is due to a fan failure. sometimes the fans get clogged up with dust that collects on them. unplug the tv and clean the fans, do NOT use canned air to clean them, only vacuum them off and a small brush to clean them. make sure all the covers are on correctly plug the set back in and see if it turns on. let me know if that works.....thanks, Terry
Sep 19, 2012 | Sony KDS-55A2020 55" Television
Changed lamp and fan and still have a flashing red light
changed my lamp on my 50"grand Vega and got one or two flashing red LEDs
forgot to put the lamp cover back tried again everything is fine now thank god,
Jul 19, 2012 | Sony XL-5100 Projector Lamp for Grand WEGA...
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 50 inch 3lcd when turn on it goes on then turns off. flashes red and blinks 4 times in standby.
4 blinks is fan error. Just clean the fans near lamp compartment by a vacuum cleaner and check the fan connectors if they are attached securely.
Oct 19, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
264 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
