Question about Apple AirPort Express Base Station with 802.11n and AirTunes
Hello, Bought a near new Airport Express for the Ex to extend her wireless network. Did a reset with the paperclip and tested it on my Apple extended network. All good. Got to her place, reset and performed a scan in Airport Utility. Located Airport Express. After setup MacBook Pro can't find the unit. Repeated several times with same result (definition of insanity!). Her Network comprises MacBookpro with Airport internal card and Thompson wireless modem supplied by ISP. The Airport Express is for streaming music. Tips greatly appreciated. Cheers.
  • Peter Sullivan Aug 23, 2010
    Thanks for your input. It seems the issue is between the network and the Airport Express. The MacBookPro accesses the internet through the wireless router with out difficulty, and during initial setup the MackBookPro sees the Airport Express. It is in the process of joining the network that the laptop fails to find the Airport Express again during the rescan.
    I hope I understood you correctly. I am grateful for the help.
    Cheers.
What you need to do is attach a network cable directly from your machine into the base station. Then launch the Airport manager utility and reset everything from there
Posted on Aug 23, 2010
    President:
  • 1,768 Answers
1. From the information given this is a VOIP enhance router with wireless capabilities. Provided by the Internet Service provider.
2. the manual shows that this router has no firmware updates and has a fix firmware. Therefore the ISP has to either walk you through setting up your Apple Express Air card on the MacBook or your MacBook is not compatible with the router. This can only be found out by contacting the ISP who provided you the DSL internet service.
I use a time capsule that is working on my Apple MacBookPro. To extend the range I purchased 2 airport express's. They are plugged in near my computer and flashing amber, they do not turn green and they...
Plug them directly into the Macbook Pro using an ethernet cable and set them up as extended networks using the Airport Utility.
Wait until you get a green light, and you should be all set!
For audio and PA system expertise, and great AA Speaker Tapes, CDs and MP3 downloads, visit my website at www.rexark.com
Dec 18, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Jun 07, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Just installed Airport Express. I can select it from iTunes on my PC running vista. The music plays but songs intermittently stop...it like it can;s download fast enough...suspect the laptop can't send...
Make sure that between the laptop and airport express you don't have devices that can interfere, like microwaves, phones, etc.
Also, if its a newer express try using the 5GHz band and that the airport is set up to "Join the network" not "Extend".
Dec 25, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple Airport Express not working
Throw the device out of the window, the apple folks are terrible and liers they mislead us into buying this device and it is not working with most Vistas.
Jul 28, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
You need to use the AirPort utility, which will walk through the setup and configuration of it. You were already on the right track to get it going. If it mentions there is an update available for it, though, do the update first.
Jul 28, 2008 | Apple AirPort Express with AirTunes...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Express Base Station with 802.11n and AirTunes  Logo
367 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
