Question about Garden
Husky 2000s Pressure washer :Will not turn on,not the motor or pump....NOTHING.The lady at the support center told me (i purchased this at a garage sale)I have NO warrenty;but she did to turn the fan manuelly because it may be stuck.......the ONLY thing that works is the green/ready light.
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
  • 242 Answers
SOURCE: pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Posted on Dec 31, 2009
  • 553 Answers
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
  • 68 Answers
SOURCE: My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Posted on Apr 21, 2010
SOURCE: husky pressure washer model GCV 160 with honda
I have the same problem lol
Posted on Apr 02, 2011
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
Blockage in pump of huskey 2600psi
You may need to have the pump replaced. Most Husky pumps under 3000 psi don't have parts available. If you bought it within two years, the pump should still be under warranty. Check with Home Depot for service centers near you. They should be able to verify if it qualifies for a free replacement based on the serial number.
Feb 15, 2013 | Garden
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
Adding pump oil to Husky HU80709 Pressure washer
If it has a radial pump, tall models have radial pumps and don't have an oil fill. One would have to split the pump from the motor. Factory filled and made as wear dated manufacturing. .
Apr 27, 2012 | Garden
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
I have a Husky 2600 PSI power washer with the Honda GCV160 engine that I can't get to start. It was okay when I purchased it from Home Depot last spring but now I've tried putting new gas in it, spraying...
You can eliminate the motor by unbolting the pump from it and then if it will start the problem is with the pump or the unloading valve.If it does not start with the pump removed then you check for spark and get the carb cleaned or have a kit put in it.If it does start then check to see if the pump turns freely,if so disassemble the unloader valve and clean and lube it so that the pump and motor can relieve the pressure it needs to when the trigger is not engaged,if the pump can't be easily turned by hand then then pump needs to come apart,dealership should do this.
Apr 13, 2010 | Karcher 2500 PSI Pressure Washer
Husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Oct 07, 2009 | Garden
Absolutely no water pressure on Husky 2600 psi w/ HOnda motor
hook up water hose dose not pump water?
May 26, 2009 | Garden
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
