Question about Dell 1320c Laser Printer
Only my black ink prints light all others print fine. I checked that the non dell ink box was not ticked. Please help so that I can use my printer.
  • 1 more comment
  • nicolas May 09, 2013
    same pb on my side. always no answer from Dell ?
    did you find a solution on your side ?
  • nicolas May 10, 2013
    solution resolved by myself
Can i print documents using black ink only when other inks are empty?
All the ink cartridges need to have ink in them to allow you to print, even if you only want to print in black only.
Oct 14, 2012 | Epson Stylus CX8300 Printer
The black print on my Dell 1320C laser printer is very light (grey) in fact. I replaced the black toner at no avail. The other colors are fine.what can I do to soulve the problem. ...
It sound like you have either a very low toner density set, which would normally be set either through the control panel or the driver, or possibly the Dell Toner conservation system turned on. Here is Dells owners manual info on dealing with light print.
The toner cartridges may be low or need to be replaced. Confirm the amount of toner in each toner cartridge.
  1. Press [Printer Status], and then click the Status tab in the printer driver.
Ensure Non-Dell Toner is not selected in the Printer Maintenance tab in the Tool Box.
  1. Click the Tool Box button.
Set Toner Saving Mode to Off in the printer driver.
  1. Press [Printing Preferences], and then click the Advanced tab.
If you are printing on an uneven print surface, change the paper type setting in the printer driver. For example, change the plain paper to thick.
  1. Press [Printing Preferences], and then click the Paper Tray tab.
Verify that the correct print media is being used.
  1. See "Print Media Sizes and Support".
Ensure that eight yellow ribbons are correctly removed from the PHD (Print Head Device) unit.
  1. See "Replacing the PHD (Print Head Device) Unit" and "Installing the PHD Unit".
Ensure that the developer motor starts.
  1. Contact Dell.
Ensure that the dispense motor starts.
  1. Contact Dell.
When you are printing many images with low density, do the Toner Refresh Mode.
  2. Press the Start button to check the density of colors.
  3. If the print is too light, Select Refresh Mode from the list. Press the Start(1)-(4) buttons.
CAUTION: Using the Refresh Mode consumes extra toner.
  1. After you complete the Refresh Mode, select Chart Print from the list. Press the Print with A4(3) or Print with Letter(C) button for 4 Colors Configuration Chart. "Printing" appears.
    Is the problem recovered?
May 06, 2011 | Dell 1320c Laser Printer
My yellow toner is empty but I would like to print in black and white. How can I do that?
in the menu options on the printer screen the will be one that says "maintenance" in that menu there will be another that says "non-dell toner" set your printer in the non-dell toner mode. this will deactivate the toner level reading and allow you to print what ever you want.
Nov 19, 2009 | Dell 5110cn Laser Printer
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
R220 inkjet ------------- won't print
No it,s not a glitch, the printer is informing you that these are also out of ink.
Go To START/PRINTERS/Right Click On EpsonR220/Printer Preferences. Tick The Box Draft Or Text.
Should Now Print In Monochrome ( Black and white )
Yoou probably have it set to photo or other colour option.
Mike @ Compurepair.
Feb 27, 2008 | Epson Stylus Photo R220 InkJet Printer
Dell AIO 924 - Can't get the Print In Black Only option to work
I had this problem. It's actually very easy to fix:
- Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Dec 05, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
Dell 1320c Laser Printer Logo
59 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
