Simpson Enduro 701 - very slow to fill up with water. Taps run strong into machine but machine seems to slow the water in and it can take hours to fill to start wash programme. Wash and spin programme is okay.
  • Kath Sambridge Aug 24, 2010
    Today is Tuesday evening I will try what you have suggested tomorrow and will get back to you to let you know whether it fixed the problem. Thank you for your quick response. Kathie
  • 1,998 Answers
If you take off where the hoses connect into the machine it connects at the water valve inspect the water valve on some hi end models that have small screens inside that get particles built up inside which prevents the flow of water from going into the machines this also happens on models such as bosh and lg upon seeing a picture of your unit do a power check also to the water valve you have to remove the compartment to check the valve make sure you are getting power to both sides of the valve your problem is within the valve weather you have sediment built up in it or its not working on one side of it. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back have a great day
rickead1
Posted on Aug 23, 2010
  • Rick Ead
    Rick Ead Aug 25, 2010
    any time i await your reply
Recently had leak in water between mains and house. Pipe replaced.Then washing machine wouldn't fill.Replaced solenoid valve -works now.The dishwasher Simpson EZISET 52B850WJ*03 won't fill.Same?
Could be dirt in the water lines after you repaired. You should always run your taps for a while before running machines that use water. I like to run water from my out side taps if I have outside repairs.
Oct 21, 2016 | Dishwashers
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson enduro 751
If your television is leaking, I suggest throwing it away.
Oct 23, 2013 | Televison & Video
SImpson Enduro 701 - motor going slow
u must check capasitor usually so good luck
Nov 20, 2010 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Locating the fusebox
The breaker box is located on the wall of your house. There is not a fuse in this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Washing Machines
Simpson enduro 701 very slow to fill and timer sticks
Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
Joyce
Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
Washing machine leaking
is the drain hose sucking water backin at the end of the cycle,otherwise turn the one tap off at a time and see if water gets in.but its normal to have water in the fill nozzle which can run in,but not normally that much.
Mar 03, 2008 | Washing Machines
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
