Panel shows Printer Error Fuser Temperature - Office Equipment & Supplies
  • 724 Answers
Head is maybe jammed and cooling fan dirty
Posted on Aug 23, 2010
Shows an error 173
Error 173 is an upper heater temperature. It usually points to the fuser unit
Power the printer off, make sure the printer is plugged directly into the wall outlet not a surge protector also remove the fuser unit and reseat. If the error 173 message continues, the fuser unit will need to be replaced.
Apr 12, 2016 | OKI B4600 Printer
HP Color Laserjet 3600 shows error 50.9 and 50.1 . It change sometimes 50.9 and sometimes 50.1 . How to solve it?
50.1 Error: (Low fuser temperature)
1. Verify the fuser is installed correctly and fully seated.
2. Check that connector J6007 on the fuser is seated correctly. Replace the connector as necessary.
3. Turn off the printer.
4. Remove the fuser.
5. If there is no conduction in the main thermistor, measure the resistance between fuser connectors J6007LA-1 and J6007LA-3. If the resistance is not 100 kohms to 3 Mohms, replace the fuser.
6. If there is no conduction in the fuser heater, measure the resistance between fuser connectors J6007LAF-1 and J6007-2. If the resistance is not 5 ohms to 1 kohms (100 to 127 V) or 20 ohms to 1 kohms (220 to 240 V), replace the fuser.
7. Upgrade the DC controller firmware.
8. Replace the DC controller PCA.
50.9 Error:(High fuser temperature (subthermistor))
5. Measure the resistance between fuser connectors J6007LA-2 and J6007LA-3. If the resistance is not 100 kohms to 3 Mohms, replace the fuser.
6. Replace the DC controller PCA.
Aug 08, 2011 | Office Equipment & Supplies
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
My dell 5210 is showing a 920.16 Service Fuser Error. How I fix this/trouble shoot?
920 Fuser Error indicates the Fuser is below temperature while printing. The fuser, melts or fuses the toner to the media and has a heat roller and a pressure roller. The heated roller is heated by a halogen lamp or in some cases a solid state ceramic heating element and is subject to failure.
If this is the first time you have seen the error
    1. Power the printer off.
    2. Leave the printer powered off for 20 to 30 seconds.
    3. Power the printer back on. If it comes up to the Ready state, try printing again.
      • If the fuser error does not return, continue using the printer as normal but observe it closely over the next few days to see if the error returns.
      • If the fuser error returns on power-up or if the error returns as soon as you try to print or at a later date, the printer will probably require service to correct the issue.
  1. One thing that you can check as well (since it is a "under temperature" error), is to make sure the printer is not plugged in to a UPS/surge protector. The printer may not be getting enough electricity to heat up the fuser. Try plugin it in to directly to the wall/different outlet and see if the error persists.
If this does not correct it, you need to replace the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Office Equipment & Supplies
Fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Nov 16, 2009 | Xerox Phaser 8400 Laser Printer
What does 50.2 fuser error mean
The 50.2 error means your fuser is not heating up. You will need to order either just the fuser HP Part # RG5-7060 or the maintenance kit HP part # Q1860-69002. Check your local computer store or we can ship the parts to you. If you need additional information contact me at our web site below.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | HP LaserJet 5100tn Printer
ENGINE FUSER, LOW HEAT ERROR
Replace the fuser, it's not reaching operating temperature within a set time (normally a thermister or the lamp is shot)
May 21, 2008 | Samsung ML-3561ND Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
347 people viewed this question
jasbo
jasbo
