Question about ASUS TUV4X (TUV4X/533/PA/6P-UAY) Motherboard
I open the intrusion selector by pulling out jumper then turn on computer then bios says system tampered i turn it off then put jumper again and set bios to default but my computer not responding to windows plss help...
  • 724 Answers
There is a jumper that resets the bios clock password etc...etc
You need to locate it 3 pin set 1 jumper and look for <norm/reset> in small white print.
Self explanitory
Posted on Aug 23, 2010
I am getting a chassis intruded system halted error when i start up my computer. I already check the net for possible solutions and most said it might be on the intrusion jumper on my MOBO but it seems...
While I am not familiar with your specific board, I think it's from an HP desktop system. In many systems there is a BIOS setting which controls the intrusion chassis setting. If you enter the BIOS (usually F1, esc, or DEL) look under the security tab or group. You can safely disable this and it will stop showing messages on this setting.
Chassis intrusion controls a sensor in the PC which detects if the side panel is opened. It is seldom used on computers these days, and is a passive control mostly to prevent theft of components, etc. but does not really offer any other security due to the nature of notifications (during bootup, or can also send administrative messages)
Sep 26, 2011 | Computers & Internet
I want to disable the system password on my dell computer
I assume that you have the password? Restart your computer. As soon as you see the dell screen, hit the f2 key. This will take you into setup. Look through the different menus and you will find the password options somewhere. You should be able to disable it there.
Mar 02, 2011 | Intel D865GBF Motherboard
Chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Jul 21, 2010 | ASUS P5KPL-AM SE Motherboard
Unlock dell inspiron 1521 unknown bios pswd
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Feb 12, 2010 | Dell Inspiron 1521-JB Notebook
Delete bios password
  • There is battery on your main board or a key named 'clear-cs'. You can hit this key for cleaning the password or if your main board does not have such a key you can easily 'put put' the battry and then (for both ways) turn on your PC.
  • If you are comfortable with messing around with the inside of a computer, then you can do it yourself - otherwise get a computer technician or the local computer whiz to do it. Anyways here goes. After you open up the case, look for the battery on the motherboard, and carefuly remove it from its socket. Then locate the CMOS jumper (it looks like a small plastic thingy on 2 pins with 1 pin beside it, within a 1" of the battery). If you're having trouble looking for it, look in the motherboard manual. After you have found it, carefuly pull straight up on it, and place it on the 2-3 pins(it was on the 1-2 pins). With the battery removed and the jumper moved, turn the computer on, and check to see if you can get into the bios. If you are able to, turn the computer off, put the jumper back on pins 1-2, and put the battery back in. Lastly put the case together and you are done.
  • The other answers listed are correct in that removing the battery you can clear your password, but there are some other things that should be said. When removing this battery not only will it remove the password, but it will also reset all BIOS settings to fail-safe defaults so if you have modified settings in the past you may have to modify them again. Also when removing the battery you may also be required to unplug your computer or at least turn off your power supply.
  • There are less intrusive ways: Do a google search for "Default Bios passwords" or "Bios password cracker". Bios passwords are very insecure, and they put default passwords in at the factory that will work no matter what. It sure beats taking the battery out.
  • Simply remove the computer case and locate the battery on the motherboard. With the computer off remove the battery for 5-10 minutes seconds and replace the battery. Fix the cover back on and power on the computer.
  • Some of these answers will break your PC for Good and you will definitely have to bring it to someone with knowledge. Have you tried simple passwords like ADMIN, or nothing(blank) or the manufacturer's name or TECH or something so simple you will cry when you find it! PS most of the time when you reset a BIOS you must manually input all the settings by hand, good luck with that if haven't written them down.
  • These are some of the default Bios passwords used with different Bios's, give them a try first. AMI, Award, bios, setup, cmos, concat, AMI_SW (case sensitive), AMI!SW/, AMI?SW/, j262
  • The second answer which is resetting the jumper is fine, but do it without taking your battery off from the motherboard. Taking the battery off from motherboard not only erases your passoword but also resets bios. So just perform the jumper part.
Mar 01, 2009 | Acer Aspire 3680 Laptop
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Nov 26, 2008 | ASUS P5P800S Motherboard
Message confirmation
You need to go into your BIOS and disable chassis intrusion detection. You can get into your BIOS usually by pressing either F!, F2, DEL, or F10 when the computer boots up. Check with your motherboard manual or look on the startup screen for the correct key.
Jun 15, 2008 | ASUS Intel 815E Chipset CUSL2-C...
Request for Help
Hi, Muhammad, It sounds to like you have been infected with a virus and will need to run an antivirus program at bootup. If you are unable to do this yourself then it is not a big job for a computer technician to do for you. Regards mistyman
Aug 14, 2007 | IBM IntelliStation M Pro 6868 PC Desktop
Motherboard
There is normally a system tamper reset within the bios settings somewhere. Alternatively try to reset by the JBAT1 terminal by putting jumper from pins 1-2 to pins 2-3 then back again and restart pc. You will have to set the time again and make sure the HDD is detected in standard bios settings and re start.
Jan 16, 2007 | ASUS A7N266-VM Motherboard
ASUS TUV4X (TUV4X/533/PA/6P-UAY) Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
