Question about Compaq (285274-001) (285274001) 20 GB Hard Drive
My Compaq HDD gave me a no disk error while using it. i tried to boot safe mode but gave me the blue screen. About 3 days earlier could not complete the regular microsoft update. all attempts to boot computer by USB/CD with Ubuntu linux unsuccessful.what do i do next
    President:
  • 1,768 Answers
1. If you are installing new hard drive to this particular PC 1st you will need to know if the PC's BIOS ( Basic Input/Output System) will allow the drive.
2.If you are trying to install the Operating system to the new drive the requirements for the Operating system have to be met.
that is RAM, available hard drive space and CPU speed.
3. Getting into the BIOS is in the instruction set in the user manual or you will have contact the technical support at the manufactuers site to see if you can install or update the storage components and or software to said PC.
Here the support site address if needed:
http://h10025.www1.hp.com/ewfrf/wc/noPfinderResults?query=285274001&lc=en&dlc=en&cc=us&dest_page=product
I hope this helps. Have a great day!
Posted on Aug 23, 2010
Black screen
on booting press the f8 key then select the last known good configuration, check it
Feb 05, 2013 | eMachines T3616 Desktop PC
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
I get a blue screen on my compaq presario what could it be
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 28, 2011 | Compaq Presario 5000 PC Desktop
Hi my compaq presario v2000 is not booting up it starts up with the manufactures screen w/the f10 option, next is the windows boot up screen and after that a blue screen appears stating some type...
Hi!
Try restarting and on the manufacturers screen start tapping f8. You will then go to the advanced options menu. Choose safe mode. if you are able to go into safe mode without errors then do a system restore and restore it to an earlier date before you had this issue. If in safe mode and you are still getting this kind of issue then it would be best to reinstall the whole operating system but make sure to have your documents and other important data backed up.
Feb 11, 2011 | HP Compaq Evo n620c Notebook
How do you fix a blue screen problem on windows xp
Then press any key.
Then type "y"
Oct 16, 2010 | Computers & Internet
Hangs on startup
Try booting in safe mode then run a chkdisk scan to see if it shows errors. To boot in safe mode power the computer completely down...wait a few seconds...when you power it back up keep tapping the F8 key on your keyboard. If done correctly a black advanced boot screen will appear with a choice to boot in safe mode. If you are able to boot in safe mode, it's likely that your hdd isn't the problem. It has to do with something in your startup programs. To disable some unwanted startup items Click Start--> RUN-> in the box type msconfig then click on the tab that says startup and uncheck any unwanted items. Reboot the machine and see if it boots regular.
Aug 13, 2010 | Compaq Evo D500 PC Desktop
Dell computer error codes 650F-0244 and 650F:1A44. Computer was running fine the day before and then without warning I had a blue screen and could not reboot, not even in safe mode. Any ideas on how to...
That's usually a damaged system file or a bad sector on your hdd. I recommend booting of your xp disk go to recovery console once you boot and run chkdsk /p and reboot when done.
Oct 12, 2009 | Computers & Internet
My windows xp cant boot propery it is restarting itself.
-Try to boot the system to windows xp cd,then run windows repair.
-repairing windows make take up to 1-2 hours depending what capacity of hdd you have but you may need to complete the repair.If repair failed to complete.
-contact manufacturer and have them diagnose the entire system. and chck for the system warranty and look if there any error code if the error code lead to replacing the hdd, then request to replace the hdd.
Oct 11, 2008 | Gateway Computers & Internet
Compaq (285274-001) (285274001) 20 GB Hard Drive Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
