Question about Whirlpool ACP102PS Portable Air Conditioner
The unit will stop blowing air after an hour and says H8. What does this mean and how do i fix it?
How to fix wen it displays a h8 code
H8 could be OutdoorCurrent transformer error
If you send make and model of air conditioner, that would help me help you?
Cheers
Jan 02, 2016 | Heating & Cooling
What does H8 mean
H8 means the float switch is activated and it is too full of water.
Aug 06, 2015 | Heating & Cooling
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
What does the message H8 mean?
Call tech support and they can give you all the info you need.
For Technical Support and Warranty Service Please Call (888) 876-5387 Or Write To: Soleus International Inc. 20035 E. Walnut Dr. N. City of Industry, CA 91789 USA www.soleusair.com
Sep 18, 2014 | Soleus LX-140 Portable Air Conditioner
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
Soleus gb-pac-08e4 h8
The unit is NOT pulling water from the air to cause this error, yes they pull moisture out of the air and over TIME fill with water. The problem is that the unit shows the H8 error even when empty. Worked for 2 months and now just keeps popping the H8 code, EVEN THOUGH IT IS EMPTY. Unfortunately sometime you find out after buying a product that it is not quality, that is the case with Soleusair. Bad company, Bad product.
Jun 17, 2012 | Soleus KFR-18 Air Conditioner
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
A/c works on and off. when it works, it works great. but it seems to have a mind of its own. help!
not real sure what you mean by a/c works on and off if your talking about the a/c button on your dash working even when its off you have a problem with that button the switch inside is stuck and it should be replaced this is a simple fix.
if your a/c is cycling on and off meaning you can hear the click of the a/c unit engage an disengage under the hood meaning inside sometimes its cool and other times it just blows hot air this means you need to have your a/c unit charged again this is a simple fix but you may require someone to do this for you. your local walmart can do this, yes its that simple call walmart for pricing
and if your air blows in the car other times it doesn't meaning you cant feel the fan blow and stop you are in need of a new blower motor this too is a simple fix requiring a few hand tools.
well I hope this helps please let me know
Jul 20, 2009 | Lexus ES 300 Cars & Trucks
Air conditional
Reset the error by disconnecting the supply for 10 sec. and " on " again, test the unit. If it wont work just call a tech, to fix the problem.
Apr 14, 2008 | Heating & Cooling
Whirlpool ACP102PS Portable Air Conditioner Logo
254 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
