Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Agitator bar makes a rattling sound when engaged.
I have a hoover U5780 900 less than one month old.  When I first got it, it was very quiet.  Now, however, when I engage the carpet agitattor, it makes a raatling sound like there is something stuck inside.  I took of the baseplate, and there is nothing in there.  It seems like the bar is coming in contact with the housing somehow.
  • 97 Answers
If you have caught anything like shoes laces in it. you will have to replace the agitator and also the v-belt. when you catch something in the machine and don't have enough time to turn it off, it can cause the v-belt to cut into the v channel that the v-belt sitts in. hope this helps
Posted on Aug 02, 2009
  • 549 Answers
Unfortunately, you may need a new brush roll.
Read this review and see what you think.
click here
Posted on May 26, 2008
Hoover 5000PH power head is feeling heavy. Cleaned everything, drive belt is fine, still not gliding across the carpet.
The belt may seem fine but could still be causing your problem. If it is over 6 months old replace the belt.
Mar 04, 2017 | Hoover Vacuums
How do I remove the agitator from an old Hoover 2315L?
Agitator itself just slides on splined shaft. At that age it's undoubtedly "growed" on there and isn't going to be easy to pull in all likelihood. Brute force and awkwardness are about the only tools as it's rarely possible to get any leverage in any place that will do any good and the edge of the agitator itself away from the center is generally to weak to use as a pry point, anyway. Some have a removable cap at the top that can either be unscrewed or pried out depending on the make/model -- if so, you can sometimes from that point actually see the splined shaft and get some solvent down there to help. Unfortunately, ime, the "goop" has always signified a transmission shaft seal failure and nothing less than replacing that seal will solve the problem
Jan 16, 2017 | Hoover Vacuums
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Hoover windtunnel
Hello--How about the Flat belt? That would be my next step...then, if it's still not turning, perhaps the beater/agitator bar's bearings are the culprit...calling for a new beater bar /agitator.
Hope this helps--
Aug 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Floormate, Spinscrub 500, I just wanted to know if tis model can also clean carpets.
SORRY , IT'S NOT DESIGNED OR HAS THE ABILITY TO DO ANYTHING OTHER THEN MINOR SPOT CLEANING. TO DO A CARPET , YOU'LL NEED A FULL SIZED UNIT. THE PROBLEM IS THAT NO MATTER WHAT BRAND YOU BUY YOU'LL HAVE PROBLEMS IN LESS THEN 3 MONTHS AS THEY ARE ALL MADE IN CHINA NOW AND THE QUALITY IS TERRIBLE. GOOD LUCK AND WHATEVER YOU DO , DON'T BUY IT FROM KOHL'S , THEY HAVE THE WORST.
Jul 09, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover beater bar is loud & vibrating.
brush roller /agitator needs replacement. part price : $25.00 to $ 30.00
May 06, 2010 | Hoover U6630-900 WindTunnel Bagless...
The power bar stopped working. The vaccume is
If its 2 months old I wouldnt stress looking at anything. Box it up and take it back. Something that flimsy doesnt make sense to keep does it?
Apr 29, 2010 | Hoover S3765-040 WindTunnel Bagless...
Brush wont spin, belt is perfect
It sounds like the motor that spins the beater brush is burned out,If it is under a yr old it should be covered by the manufacturer warretee. Find a Hoover service center that does warrentee repairs.
Jan 25, 2010 | Hoover U8188-900 Bagless Upright Vacuum
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
415 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
