Question about Nokia E71 Smartphone
Hi my phone was usually hot this morning, was fully charged & now has gone flat - could this be a short circuit & should I get a new battery or get phone tested or other? Thanks
    Problem Solver:
  • 10 Answers
How long Do you keep your phone charging? If your Phone passes an extended amount of time showing "Phone Charged", then your phone's battery was overcharged. I recommend replacing the battery...
Posted on Aug 24, 2010
Testimonial: "Exactly what my IT team has suggested"
Batteries and phone very hot
There is a short in the phone that causes a high rate of battery discharge resulting in a overheating battery.
This cell phone is faulty and I suggest you get a new cell phone.
May 21, 2013 | Nokia 5130 Cell Phones
I charge my sony ericson P990i the whole nihgt when i take it off in the morning only 15 minutes then it is flat again
either, your battery is dead or your phone has a short circuit that drains your battery instantly.. or charging system is spoilt.. have those checked by a service man.
Aug 02, 2011 | Cell Phones
No power, even the battery is new and fully charge
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 18, 2011 | Cell Phones
The battery is fully charged but the phone does not turn on
1. Water damage
2. Fall down
May 24, 2011 | Samsung Cell Phones
Hi , The problem with my phone is that even though there is full charge , suddenly all the charge is depleted and the phone dies. I am unable to figure out if there is some loose connection with the...
"The charge is depleted and the phone dies" This happens in two cases....
  1. Your batteries are dead and old. Try replacing the batteries
  2. This can also happen if there is a short-circuit somewhere in the connection.
Try exchanging your batteries with a new one or with another phone of same model. If the problem is gone then your batteries were dead but if it arises again there must be a short-circuit somewhere, get is checked....
Oct 01, 2010 | Uniden 5.8GHz Dual Cordless Phone
My cell get heated when i put charge batt chg circuit of cell isnot functioning i get batt chg from universal charger nokia1100
Usually it is the battery hat is becoming old enough to internally short and this will cause it to work poorly and not ever fully charge, and get warmer than normal or hot when attempting to charge for more than 1/2 hour. Sometimes the chargr can go bad and over charge, thus making the battery too warm. if you have a car cell phone charger that plugs into cigarette lighter outlet , you can atach this and see if battery gets too warm, but these chargers usually charge faster than electric plug-in type, so expect some warmth within 20 minutes, but again if too warm than you know itis the battery. For these unnits batteries are not expensive.
Apr 28, 2010 | Nokia 1100
My iphone gets hot when I try to charge it. The battery life indicator shows the full sign but the charge bar(the one that gets green) only shows that it's less than half full. Then it gets drained...
dear sir,
too many causes can happen for this types of problem.
1) if the battery condition not good, i mean (any type of manufacturing fault)
2) battery contain a internal electronic circuit. if any types of problem like short circuit or semi short circuit.
3) if any short circuit in the charge control section in that phone.
now i think first u can check with a new battery & observe it if any improvement.
otherwise u contact with any qualified service technician please.
thanks
hasan mahmud zilany
Oct 19, 2009 | Apple iPhone Smartphone
Good morning, I must change the battery but I
no more then 2 amps rated for charger
most chargers Amp meter
will read zero when battery fully charged
and high current if battery not taking charge is shortted out
should check why battery not holding charge
Sep 10, 2009 | 1982 Suzuki GSX 400 FS impulse
1993 XJ6 Jaguar has a flat battery every morning
Hi
Disconnect battery overnight, if flat in the morning, fit a new battery !
Good Luck !
A Fixya rating would be nice thank´s...John.
Feb 19, 2009 | 1998 Jaguar XJ8L
Battery went dead
Most likely you have a bad battery you can check by taking out the battery and feeling on it if it is flat than its good if it has a bump on it than it is no good.
Jan 04, 2009 | LG VX-8700 Cellular Phone
Nokia E71 Smartphone Logo
115 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
