My driver for processors is abnormal - Computers & Internet
  • 724 Answers
Manufacture help download the normal
Posted on Aug 23, 2010
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
Oct 15, 2013 | Brother MFC 6490CW InkJet Printer
ERROR L1-00
Scanner feed trouble.
The scanner does not complete feeding in the specified time.
Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Use SIM 1-1 to check the mirror reciprocatingoperations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between the mirror motor and the MCU PWB.
Replace the mirror unit.Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home positionsensor.
From the service manual: http://www.scribd.com/doc/74632095/ARM206-M161-SM-GB
Oct 12, 2012 | Sharp AR-M206
Computer was shut down abnormally following a power failure in a thunder storm. No apparent physical damage to machine but will not reboot. Machine gives single long beeps at 6 second intervals. BIOS is...
take out the processor chip and clock battery along with the ram while it is disconnected from the wall outlet and wait about 5 mins. after you put it back together, if the problem persists the processor might need to be replaced or the entire motherboard its self.
Jun 28, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
Amd athlon 2800+ drivers
Click here to download the drivers for your Processor.
Select Processor for option 1
Select AMD Athlon 64 bit family for option 2
Now click view results.
It will then show a list of the available drivers for your processor.
Select whichever is appropriate.
You would need the AMD Processor driver version 1.3.2.0053
damnor01
Dec 29, 2010 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Hello Guys, i my monitor will not display anything even if the system unit is running? and processor is abnormally heating, i just bought a new vga card and it started this, i have intel core 2 duo @...
hurm,try change the processor fan.. or your monitor did not support the vga card.... monitor have the resolution.. or you can change the power supply to 500w..
Oct 08, 2010 | CTX S762A 17" LCD Monitor
Setup encountered an abnormal program execution
you got the wrong driver or you lost part of your driver you need to reinstall the complete driver again.
Jan 13, 2010 | D-Link DP 311U (DP-311U) Print Server
What is a coprocessor driver means? what can it do to my computer
a co-processor is a processor that works alongside the primary processor and performs special tasks. therefore the co-processor driver is just the driver for it, like the driver for a graphics card
Oct 12, 2009 | Computers & Internet
ATI RADEON X1650 Pro Problem
The graphics card might not be working in sync with your processor. Get it checked WHY this is happening. Probably a faulty connection somewhere. See if you can find one before getting it checked.
Sep 13, 2008 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Lens malfunction
hello, you are right. Actually there is some problem with lens assy.. When you turn on the camera the processor of camera start to check whole camera including mechanism. when it find something abnormal,it will not let to turn on the camera. This is the problem. I think there is some problem in lens mechanism and i and processor also suppose something abnormal in lens mechanism which makes buzzing sound. it is advisable to go to sony for professional repairs. hope you got it...
Aug 01, 2006 | Sony Cyber-Shot DSC-P92 Digital Camera
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
