Hai hello i have acer laptop 235NLL ,my problem is when i was kept for charging it will work for 5 to 10 mints only after green indication also not blinking it shows disappearing the charging mode,this i was conform through battery meter software which is in built in XP ,Each and every connector that i have verify from power card 2 charger connector. so plz plz tell me what i should do replay soon thanku
  • 724 Answers
5 or 10 min of runtime on a single charge?
Batteries are needed to be changed.
Posted on Aug 23, 2010
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Hello mere pass acer 5735 netbook hai jiske bios me password lag gaya hai plz help me now iska defult password kya hai
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 18, 2010 | Acer Aspire 5735 Notebook
Hello sir, mere pas Acer Aspire one 250 notebook
1.use the recovery option by alt+f10 to recover the your os.restart your machine and continuosly press ALT+F10 and choose the factory restore option.
Nov 17, 2010 | Acer Aspire 4720 Notebook
My Acer Aspire 5600 has periodic charging problem. Will charge up OK when switched off. When switched on, after a while the battery indicator changes from green to amber and then starts flashing. Then the...
I guess your charger has very low power (low wattage). That is why it charges the battery when the laptop is off. But as soon as the laptop is on, the charger can't keep up with the power dreained by keeping the laptop on and eventually the battery runs outr of juice.
According to the user's manual (http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS5600_3680_UG.pdf)
I suggest you get a charger with at least 90 W.
Mar 25, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
My Acer Aspire 5000 won't turn on. I hit the power button, the light turns on for half a second then blinks off again. The HD doesnt start, neither does the fan and the screen never coms on. The battery is...
sounds as if the laptops in hibernation or sleep mode.
Try refering to the user manual regarding the mentioned points.
also try alternating the memory from slot to slot, 1 faulty slot or ram module, will cause the computer not to boot.
Finally, if this is a model that has a ribbon-cable from power switch, to motherboard. ensure it,s inserted correctly/square et,c.
Hope this helps, thankyou for using Fixya.
mike @ Compurepair.
Nov 26, 2008 | Acer Aspire 5000 Notebook
Hello......could you suggest me how to format acer 5315?
ALT and F10 from power on to acces the restore partition on ANY acer pc or laptop
Nov 24, 2008 | Acer Aspire 5315 Notebook
Laptop Acer does not see AC power
ok..try it without the battery installed at all, and let us know how that works..AC power only..
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
