I have a 1999 RCA TV model # P52921. It completely shut down. It has no sound and picture. I checked the fuse with my tester and there is power coming out of the fuse. I hear a slight, faint, pulsating chirping sound when I plug it in but nothing else. I'm not an electronics person, but I have skills on soldering. I have carefully marked all the plugs and removed them from the main circuit board. Looking at the board, I see no obvious burnt out parts. Does this sound like a common problem with this model. If so, what may be the common solution in your opinion?
  • 901 Answers
Check SMPS power supply. DC voltages. First check the power supply
bridge/ diodes. Then check DC votage should be 70% rating of the
capacitor voltage. If the capacitor is dry it will show low voltage.
But the diodes should be OK. Check the high wattage resistors
connected in the power supply. There will be a resistor in the
ac input also. Beyond this check all +DC voltages.
Posted on Aug 23, 2010
Requesting a suggestion
its seems as though you may have to check your capacitors on the power supply board. if they are raised or leaking, they need to be replaced or you may need a whole new optical unit which pretty much cost as much as a whole new tv.
Apr 03, 2012 | RCA Televison & Video
Dead
Check this site for some useful info: http://wa6ati.com/CTC195-197.html
Feb 15, 2008 | Televison & Video
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
Mr rca rear projection tv just came on last night on it's own. i can now only power it on by the front power button. tv has no response to any other buttons on front console and no response to remote.
hi,you need to replace the front control panel, 1 or more of the tact switches have failed, if your proficient at solder work you can replace the switches, if not replace the small board behind the front buttons, available from any local tv shop just bring them the complete model # of your tv, gl, video-tek
Jun 04, 2009 | RCA P52921 52" Rear Projection Television
Rca P52921 52 in. projection made apopping noise
sounds like possibly the high voltage amplifier' just a guesas
May 08, 2009 | RCA P52921 52" Rear Projection Television
TV turns on can hear sound then shuts down.
Did you check the high voltage transformer and the high voltage splitter (distributor). RCA HVT is known for going bad. i have the part number for both if needed. 5520-559-5774 john
Aug 14, 2008 | RCA HD56W58 56" TV
RCA p52921
You will need to connect your antenna and do an auto search. When the search is over you might have to choose the broadcast option over the cable selection. That might bring in the picture.
Jul 21, 2008 | RCA P52921 52" Rear Projection Television
My tv has sound but no picture
Check to see if you aux inputs pass the audio and video. If you see picture and have sound then your problem is most likely the tuner.
Jul 06, 2008 | RCA P52921 52" Rear Projection Television
RCA P52921yx2 WIll not power on only clicks
try to check the h-transistor and test it with 360tr multi tester and if not deffective try to also check the r2m zener diode
Nov 29, 2007 | RCA P52921 52" Rear Projection Television
52 in. rca tv model p52921
DO not have set fixed file insurance if you have it! this set can cost more then it is worth.Save your money buy a new one.Thankyou for using FixYa. Have a Nice Day.
Nov 08, 2007 | RCA P52921 52" Rear Projection Television
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
