Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
WHY WONT STARITE PUMP TURN ON - Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
  • Dale Cobb Aug 23, 2010
    there can be many reasons. does the motor hum or make any noise when you try turning it on?
    Top Expert:
  • Sta Rite Master
  • 6,498 Answers
Bad start up capacitor replace pump
Posted on May 22, 2016
3 Suggested Answers
MOTORWIZJ
  • 1363 Answers
SOURCE: 1 HP StaRite Pump 15" inout Center Discharge 240V wHair Lint Pot: Impellers on pump wont turn. Motor not running...
what happens is the pump gets staved for water and this damages the shaft seal, water slowly over time leaks into the motor and pollutes the grease int the bearing and causes it to fail. it's fairly easy fix, just have the motor rebuilt by your local pool pump motor repair guy for about 75.00 and your back up and running. beats paying 200.00 or more for a new motor.
the sta rite is the top of the line pump, i have had them in my shop over 40 years old ! ask your motor repair guy how to get the most life out of your pump. knowledge is king .. remember to prime the pump after any pump repair !! .. jay longwood florida
Posted on Nov 02, 2011
MOTORWIZJ
  • 1363 Answers
SOURCE: removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Why motor hums but impeller does not turn
with motor off try turning the shaft of the motor from the back a few times then try to start up again if it doesnt need a new motor
Jun 07, 2014 | Pentair STARITE PUMP HOUSING / TANK BODY
How to prime sta rite pool filters
put water in pump basket and turn on after opening valve 1 at a time
Nov 03, 2013 | Sta Rite StaRite DuraGlas Pump 34 HP...
When i turn the switch on the pump buzzes and wont start , then trips the breaker . Help .
Either the pump is seized or the motor start capacitor is open or blown. If you can spin the impeller with your finger it is most likely a start capacitor problem.
Aug 20, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
I have- starite pump it was working fine last night but this morning there was no pressure at all i wonder if is the water tank the pump is running fine but there is no water
It sounds like you have blown your shaft-seal. When this happens the pump runs dry. If you know that you have water but it will not pump, and all the cover and housing o-rings are good, it is the shaft seal. (unless the internal impeller is just broke, but this is unlikely)
Fix: Turn off power. Remove V-clamp holding wet end together. Remove diffuser inside wet end (need flathead screwdriver).
next remove rear electrical panel on the motor. Using s 7/16" wrend, hold the end of the motor shaft by the electrical end (where you removed the cover) while turning the impeller counter clockwise (note: some impellers have an impeller screw inside which unthreads CLOCKWISE) untill impeller is off. Replace carbon shaft seal inside. Reverse and prime and then restore power and start.
Oct 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
I have a Starite pump but one of the wires is broke. I don't know where it belongs.I believe it's set up for a 220 line but would like to know if it could be changed to 115
On the pump tag there is a schematic of the electrical. one for low voltage and on for high voltage. look at the high voltage. the A and B terminals or for the wires in the motor. the lines in are for the white and black wires coming in from your power source.connect the lines in to the suggested terminals and it will power up.
The Pool Tech
Jul 14, 2010 | Sta Rite Starite Duraglas Inground Pool...
May 17, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
I turned my starite pump on and it just hummed for about 5 seconds then cut off. What could be wrong?
Your pump motor or impeller is seized. Disassemble the pump housing and check the impeller to see if it spins freely. If not then check for debris, if impeller appears to be free of debris, then check the shaft seal and motor. If the shaft seal is leaking water, then the motor bearing is likely rusted and will need to be replaced. There are 2 bearings, replace them both along with the shaft seal
Apr 11, 2010 | Pentair STARITE PUMP HOUSING / TANK BODY
Removing a staRite pump
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
90 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
