Question about HP OfficeJet G85 All-In-One InkJet Printer
The carriage is constantly jamming; every black catridge I put in starts leaking. How can I fix it?
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Posted on Sep 23, 2010
My troubles started when I inserted a non-hp black ink catridge - kept getting 'alignment failed' displays. As I could not make any headway I inserted a new HP catridge - now it keeps saying I have a...
You have to open up all the covers and dont forget there is normally one at rear.
re alignment make sure you put the paper in the scanner the correct way, it is easy to have it 180 deg out.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | HP Office Equipment & Supplies
Carriage Jam Clear Carriage Jam
Open cartridge door. Put very thin oil on the carriage shaft(silver bar that runs through the catridge holder) on either sides of the cartridges .
Good luck
Apr 22, 2010 | HP PhotoSmart C4385 All-in-One Printer
Yellow light for ink missing is blinking all the time i put the two new black and color catridge
This is a typical cartridge problem.Try clean the contacts on the carriage unit using piece of cotton and some alcohol.If this not help open the printer cover and look when carriage unit stops.On the carriage unit have a yellow arrow.In the left sidе of printer, where the carriage stops have a two icons.If the arrow shows left icon change the color cartridge.If shows right icon change the black cartridge.If this not help there is a problem in carriage unit and your printer need repair.
Nov 05, 2009 | HP DeskJet 1280 InkJet Printer
Paper jammed. Once pulled free and clear, it
if you pulled the paper out of a jam and it was not done correclty
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Check the lever for the catridge. sometime the catridge does sit properly in the carriage and it will hitt the side of the front cover when it moves. Push the catridge in place to try solve the problem.
Aug 10, 2009 | Canon PIXMA MX310 All-In-One Printer
I turned my printer on and it said open door. clear cariage jam then press enter what is that?
Hi and welcome to FixYa,
with the indulgence of mackenzie123...
A 'Carriage Jam" error indicates that the holder of the ink cartridges (called carriage) which includes the print head cannot move or complete its sideways movement. Three (3) possibilities:
  • it is really jammed. Paper debris is blocking its path and therefore must be cleaned;
  • the guide rod / rail has lost / dried up its lubricant and therefore the carriage could not move easily. The guide rod/rail as the name implies is the provides the path of motion;
  • ink smears on the encoder strip. The encoder strip is the long narrow plastic with barcode like markings. This tells the carriage where it is. An ink smear would block the markings and confuses the carriage.
Hope that this be of initial help/idea. Good luck and thank you for using FixYa..
Apr 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
CARRIAGE JAM
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 01, 2009 | HP Officejet 4355 All-In-One InkJet...
Carriage Jam
Jan 18, 2009 | HP Officejet 4110 All-In-One InkJet...
Catridge jammed
check to make sure there is nothing obstructing the carriage and the paper feed area, sometimes things can get in there mysteriously :) I have found all kinds of things, there could also be a small bit of paper jammed up in there keeping things from operating smoothly.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Carriage Jam
I'm sorry to be the bearer of bad news, but that is the only way of fixing the printer. Yes you are right in stating that fixing it will cost as much as a new printer, but the question you have to ask yourself is this, do you want a new printer with more features or better ones? Or do you just want to shell out the same amount for the same printer to be fixed? Remember, you can always find a small business that's able to repair computers and they could do it cheap, like 50 bucks, but still that's your only option.
Aug 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet G85 All-In-One InkJet Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
