Question about Bernina Sewing Machines
My Bernina is sewing backwards and driving me up the wall!!!! What can I do?
  • 109 Answers
Depending on which Bernina you have, check the manual for "continuous reverse." If I remember correctly you either had to press the reverse button twice in succession or you could set it on your screen to do it. Hope this helps.
Posted on Aug 23, 2010
Why is my bernina 1080 only sewing backwards?
Perhaps this will help:
Bernina 1230 Reverse Button Fix
Most likely it is an issue with the Reverse mechanism.
http://www.fixya.com/tags/bernina_sewing_reverse
Be sure to keep your machine cleaned and frequently oiled.
Aug 30, 2016 | Bernina Sewing Machines
What would cause my Bernina 1230 to only sew backwards?
Hmmm, not sure I can answer your problem. I have several Berninas (older than your 1230) but have not had this problem. Wondering if your machine needs oiling--like maybe the reverse mechanism is stuck. With mechanical machines, I've been able to loosen stuck parts using heat from a handheld hair dryer. Not sure that would work on your machine.
sewing patternreview com
Apr 06, 2016 | Bernina Sewing Machines
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. · .... control the sewing speed by pressing the foot
Feb 03, 2016 | Bernina Bernette 75
Bernina 530 I inherited a Bernina 530 Record and am trying to learn everything about it. How do I get it to stitch backwards?
Download a manual at Bernina.com, select Support, and go to Out of Print Manuals.
http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
Jan 19, 2014 | Sewing Machines
Is there a button on this 807 machine bernina which you can press for it to stitch backwards like on the singer machine 507 as its saves time on tiring ends up at the beginning and end of sewing thank...
The stitch length control is moved upwards, beyond the 'zero' position to make it sew backwards. To demonstrate, with the machine off, adjust the stitch length to '2' using the knob on the stitch-length lever. Now push the lever upwards until it stops - it will go past the zero position and this is now in reverse mode.
May 15, 2011 | Bernina Activa 130
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
My bernina bernette 66 will only sew backwards! Help
there is a lever on the right, push it down, if its tight unscrew top of it a little
Sep 26, 2009 | Bernina Bernette 75
Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
Jul 22, 2009 | Bernina Sewing Machines
Sewing Machines Logo
435 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
