Question about Canon PIXMA MP470 All-in-One Printer
Usb cord wont fit in back of printer - Canon PIXMA MP470 All-in-One Printer
Same issue.
USB won't fit in back of this printer.
how do I attach the printer to the computer to print docs?
Posted on Oct 04, 2008
How i connect hp officejet 5610 printer to my acer aspire 6930 g
first put the cd that comes with your printer and install all the drivers and software then after this is done plug in a usb cord. take a usb printer cord plug in the one end that fits your printer and the other end is for your laptop plug it into your usb port and thats it
Sep 28, 2012 | Acer Aspire 6930-6941 Notebook
Where does the power cord plug in to?
The back of the printer at the lower left corner near the USB port.
Jan 23, 2011 | Lexmark X2600 InkJet Printer
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
Problem with USB cord, but the usb cord fits in printer and laptop fine. Computer screen says Printer ready, but when I try to print a message says check USB cord. Don't understand
Try using another USB port if you have one. If the others are full, disconnect one of your devices from the USB port and try your printer there. For some reason, switching the USB port sometimes makes devices connect. Good luck!
Mar 13, 2010 | Lexmark X2600 InkJet Printer
My usb wont fit into the back of the printer
printer type? brand? the normal usb connector will not fit unless it has one.. normally it will be a firewire type connection with a male usb connector on the other end.
Aug 14, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Lexmark x1270 printer wont turn on
If you are looking at the back of the printer, just to the right of the USB port is where the power cable goes. ( o o ) <--- Kinda looks like that but vertical, not horizontal as I drew it. Hope this helps.
Jun 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Wont turn on!
Unless the power cord is loose, it sounds like the unit is defective. There are two places to check the power cord. The 'brick' has to be firmly inserted into the back of the printer and the cord has to be properly fitting into the brick. If all is well there, it sounds like something more drastic is wrong.
Steve
Feb 26, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lost cord
hi,
you can try looking at thrift stores, usually they have a "cord wall" or cord bin, that lexmark I believe has the power supply that kind of fits into the back of the printer so it should be easy to spot, but when you look at the power suppliy make sure it says lexmark on it before you buy it,
just an idea
J
Jul 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
USB cord Wont Fit?
The S730 has an uncommon USB input socket. You MUST use the USB connector which came with THIS camera.
Jan 07, 2008 | Samsung Digimax S730 Digital Camera
Canon PIXMA MP470 All-in-One Printer Logo
old marine
old marine
