I have samsung sens R530 when turn on ther is power but video resolution is dim. brightness button not working. i have seen the windows on screen but it's so dim.
  • danet5658 Aug 23, 2010
    please help i have samsung lapto sens r530 resolutio is dim. brighness button control not working.
kykeaton
  • 35 Answers
SOURCE: Monitor resolution re-set with a Samsung MW225 and Windows Vista
yes if your comfortable with editing your registry.
remove the following: (backup your registry first)
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device0]
"DefaultSettings.XResolution"=-
"DefaultSettings.YResolution"=-
"DefaultSettings.BitsPerPel"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\Settings]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device3]
Posted on Feb 23, 2008
jemmyrash
  • 180 Answers
SOURCE: Samsung 19" monitor control problems
Your logic board need to service.
Posted on Apr 20, 2008
Theknack
  • 144 Answers
SOURCE: my screen has dimmed but the cursor remains normal
I think its just like driver problem or you adjust the color in under advance button in the screen and resolution setting
takecare
Posted on Apr 29, 2008
rolltape
  • 58 Answers
SOURCE: Samsung SyncMaster 931BF 19" Monitor.
This is because your screen is not compatible with any resoultion past 1280 x 1024. Look at your screen's specifications here: http://downloadcenter.samsung.com/content/UM/200602/20060210090838125_BN59-00521A-01Eng.pdf (Page 76 listed as Maximum resolution)
If you want to go past that, you must purchase and/or use a different monitor. Just be sure to look at the Maximum Resolutions BEFORE you purchase a new monitor!
Posted on Nov 25, 2008
mneilsen2084
  • 342 Answers
SOURCE: my ipods brightness doesnt work is very dim when i turn the brightness up or down nothing happens the screen just stays very dim all the time i restored the ipod and still the same
Well as you probably figure, you're back light has probably crapped out. However I would reset it by holding both the menu and center buttons at the same time until you see an apple appear on the screen. If the back light does not come on then, try the settings one more time. If there is still no backlight at this point; I would go ahead and connect it to your computer and restore it using itunes. Sadly if you still cannot resolve your issue at this point you will probably want to call apple tech support about it at 1-800-APL-CARE (1-800-275-2273) If your still under warranty they should cover all expenses on the repair or replacement. (Just don't admit to any kind of accidental damage)
Posted on Apr 22, 2009
Is there an easy way to adjust briteness on my samsung r530
if you're using windows 7 go to control panel and choose power option and you'll be able to change settings (there should be a slider for battery and plug in options)
Dec 01, 2012 | Samsung R530 Notebook
Problem with Samsung R530 laptop screen.
Laptops do not fair well if liquid was spilt, and it does not take much. Remove main battery and turn on, if okay! battery needs to be replaced, next remove ram one at a time and power up making sure you always have one in the laptop, last! hook a spare monitor to the video output usually on the back, if okay! the LCD on the laptop has a bad inverter board, or defective backlight behind the LCD. Now if both show the same symptom it is the Video Graphics Card usually built into the motherboard.
Mar 19, 2012 | Samsung R530 Notebook
Simple problem. The clock display on the Motorola DCX3501-M is very bright and is located in our bedroom. Its like trying to sleep with a 40 watt light turned on all night. Is there a way to dim the...
From "asvforum"...note this may require firmware upgrade of the device in order for the dim functionality to be present:
"With the unit currently powered on and the TV powered on, press POWER OFF and then press MENU. You'll then be presented with the "hardware setup menu" where you can set things like "native" output resolution vs. fixed output resolution, etc.
I believe that there is now a "display brightness" setting in this menu.
Of course I could also be wrong, and maybe this display brightness adjustment is just part of the "user configuration" setup menu. With the unit powered on, press MENU twice to get the main menu. Navigate to the Setup button and push OK. Navigate to Cable Box setup button and push OK. If the display brightness setting is in this "user configuration" setup menu, it should be seen somewhere in here.
But I think I remember reading that it was in the first "hardware setup menu".
Jun 05, 2011 | Televison & Video
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Samsung SyncMaster 931BF 19" Monitor. Screen was working fine. But now after raising the resolution past 1280X1024, the screen wouldn't display anything. I tried it on my older monitor, a CRT. It...
Nov 25, 2008 | Computers & Internet
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
My screen has dimmed but the cursor remains normal
takecare
Apr 28, 2008 | Computers & Internet
Samsung SENS R65 LAPTOP
look at the screen held in a bright light at an angle do you see the desktop dimly .
if not try the function monitor key,
connect an ext monitor to verify the video card is working ,fn monitor .
if you see the desktop dimly then the inverter may be out or the lamps.
Apr 24, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
449 people viewed this question
David Payne
David Payne
