Question about Timex Ironman Triathlon 51931 wristwatch
I need a new battery cover for my GPS 3D. Is there anywhere to buy a replacement?
    President:
  • 2,501 Answers
Go to "timex.com" and click on "warranty" at the bottom of the page and you will see a "help" menu.
Click an repairs and contact one of the addresses there to find out how to get the item you need.
Posted on Aug 23, 2010
Need battery replacement. Who does & rough cost?
A battery for a watch?
There's a few standard sizes. A battery takes 2 minutes to replace. Any jewellers shop would do it for you - or a market stall .. or really, anywhere that sells batteries.
You can prise the back off your watch and remove the battery yourself. I bet you wouldn't pay more than 5 dollars for a new battery
Mar 07, 2016 | Watches
S149 will not start
You may need to reset it. Unfortunately, this can not be done without taking the unit apart. I fixed ours yesterday when the screen was blank, by replacing the internal battery. Part of that process is resetting the clock.
This might solve your problem and so, I have included my full instructions for replacing the battery.
You will need a small phillips screw driver, a paperclip and a new battery. ( a CR2032 works fine and can be bought anywhere)
Keep in mind, you will be handling some electronics, so keeping static discharges to a minimum is a good idea.
*Place the unit face down on a table.
*Remove the battery cover and batteries.
*Using tape, cover the two switch sliders located on the sides of the unit so they stay in place when you remove the back.
*Remove the three screws inside the battery bay and the four longer screws on the main body.
*Before you gently seperate the back from the front, take note of the two battery connections that are on the outer edge of the battery box and are opposite of the strap brackets. These will need to be coaxed through the plastic as you pull the back off. You will also need to manipulate/open the paper roll cover.
*Remove the back cover.
*The top circuit board and printer are connected to the lower circuit board and front cover by a white ribbon cable and wires to a switch. Gently lay the top circuit board and printer to the side, being careful not to unlpug the cables.
*Locate the battery, it is standing on edge. Note the orientation.
*Straighten the paperclip and make a hook so you can remove the battery.
*Install the new battery, taking care to not bend the connectors.
*A label on the inside of the back cover details the reset procedure. Locate the AC and + on the lower circuit board.
*Use the paperclip to make an electrical connection between those two points.
*Reassemble the unit in reverse fashion.
*Pay attention to the switches on the top circuit board and the slots they fit into. These are the black switch sliders that were taped to the side.
*The printer assembly should set into place.
*Reinstall the back cover, coaxing the battery connections through their respective holes.
I hope this solves your problem.
Apr 12, 2014 | Seiko S149 Stopwatch/Printer
Cl-1007
You need a 3-jaw watch wrench to unscrew the back of the case. Then you can see the battery type. Buy one from anywhere that sells watch batteries.
Dec 07, 2012 | Columbia Elkhorn Light-Up Watch - Large
Blank screen with a line. Why?
I have the same, assume the watch battery is gone. Handbook says the whole timer has to go to a dealer to replace the battery.. the printer batteries are easily replacable, I wonder why they made the watch battery such a costly deal?
Sep 06, 2011 | Seiko S149 Stopwatch/Printer
How to a recharge a citizen eco drive silhouette ladies watch..model number sy2030-54E?
Do you mean, you haven't been wearing that watch but to put it in the drawer for a long time?
If so, to recharge the battery, just put your watch outside or anywhere it can catch the sun ray or day light. After few hours or about a day, the battery has been re-charged and your watch will work.
If it still doesn't work after doing that, buy a new watch. Don't bother to repair the watch or to replace the Eco-Drive battery, because of the cost.
Feb 16, 2011 | Citizen Silhouette Eco-Drive SY203054E...
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    Seiko Stop Watch S149 Stop watch has new batteries in and they are put in correctly but nothing shows up on the screen. The paper feeder works so it is getting power.
    If you go to "www.sportscounters.com/seiko-s149-stopwatch-printer-all-in-one" you will see a telephone number, try calling them for advice.
    (This problem is fairly common after replacing batteries, so I suspect that there is a procedure for resetting the timer.)
    Feb 25, 2010 | Seiko S149 Stopwatch with Built In Printer
    How do i change battery on columbia 5017
    Open watch caseback. Undo the contact covering the battery. Read the writings on battery and buy exactly the same one. Get the old battery out and replace with the new one exactly the same way as it was. Redo the contact. Put caseback back on. Reset the watch.
    Rate, please.
    Jul 09, 2009 | Columbia All Sport Digital watch
    Battery....can I get a battery replacement anywhere?
    Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
    Dec 08, 2008 | Skagen Watches
    My watch needs a new battery.
    There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
    Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
    Timex Ironman Triathlon 51931 wristwatch Logo
    55 people viewed this question
    Top Timex Watches Experts
    Ross Keen
    freddyfox
    Jerry Greenberg
    Jerry Greenberg
    Are you a Timex Watch Expert? Answer questions, earn points and help others
