Question about Canon MX310 Office All-In-One Printer
When the paper is feeding into the printer, the upper corner gets bent over. I can't see anything stuck any place. Any suggestions?
    Genius:
  • 2,785 Answers
To solve this problem the printer has to be opened. if possible you can take it to service centre
Posted on Aug 23, 2010
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper jam
it is needing a hard reset sir.
nothing big
Apr 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper feed problem - uneven feed
If you don't see anything stuck down where the paper starts in, you might have a bent frame. What I see the most on this model is the center gets smashed down by luggage piled on top or tools and it bends the frame so paper can't pass thru. I have been able to rescue a few of these but usually you need a new print engine that runs around $169.00.
Nov 19, 2009 | Canon PIXMA iP90 Mobile Printer
Paper feeds only an inch or so and then hangs, giving an error message. There appears to be nothing blocking the channel. The toner is almost out, does this have anything to do with the feeding mechanism?
Look for paper clips/ garbage that fell in or look for bent paper out sensor in the paper path (possibly left over paper from a previous jam or a piece of stuck label because the glue melted because you may not have used labels for *LASER* printers
Oct 16, 2009 | Samsung ML 1430 Laser Printer
Duplex mode, paper retracted and DISAPPEARED!
For duplex the paper feeds into the bottom paper tray, you need to make sure that paper is not stuck in the bottom area.
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
HP 5610v states 'paper jam' and there isn't one - how to reset?
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper will not feed into the printer.
I opened up my CX4200 and cleaned the feed rollers with a Q-tip wetted with a bit of cleaner, now it feeds fine. Looked like there was some dried ink splatter on the rubber rollers, that was probably preventing it from gripping the paper properly.
Oct 18, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Canon MX310 Office All-In-One Printer Logo
old marine
old marine
