Question about Electrolux Dishwashers
Fault code CD for electrolux ex600 dishwasher
Electrolux WT55 fault code A1
AL_1
Appears with hood closedif the top limit switch (FC_UP) cuts in.
Appears with hood closed, if:
  • the bottom limit switch (S3) returns to the rest position_;
  • the top limit switch (S5) cuts in;
  • "S3" does not cut in.
Dado
Nov 13, 2014 | Electrolux Dishwashers
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Electrolux dishwasher won't run through a cycle?
So it would be desirable to write the ERROR appeared in
Dado
Aug 02, 2014 | Electrolux 24 " White Built-In Dishwasher...
Electrolux EX600 Dishwasher loosing power during wash cycle
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
Feb 26, 2013 | Electrolux Dishwashers
Wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
Dec 04, 2011 | Electrolux Dishwashers
Electrolux dishwasher shows code 10 not filling fault and code 20 not draining fault but when running you are able to hear it filling and draining. Whats the problem.?
I had the same issue (Electrolux ESF 6251). I had both error codes 10 and 30. I found that the short hose connecting the inlet valve (solenoid) to the tank was cracked. That explained error code 30, but even after replacing the hose I still got error code 10. I checked water supply and also drain hose and filters. I realized that I had recently tried to flush out lime scale and suspect that the drain or pump had lines could have clogged up. I tried pumping into the floor drain inside the dishwasher (removed the filter cartridge and screen) simply with a suction cup like you use in the kitchen sink. Voila. Now it works again...
Sep 17, 2009 | Electrolux Dishwashers
Electrolux dishlex dishwasher
www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Jul 25, 2008 | Electrolux 23 in. ESL624 Built-in...
EX600 Electrolux Diashwasher
wanna give the model number if possible, sounds like your're having a problem with the display board malfunctioning, theres a kit available for the fix need to know the model though, any chance this is under 1yr old??
Mar 15, 2008 | Dishwashers
Dishwashers Logo
214 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
