Konica 7045 I was recently given a Konica 7045 model printer.I transported it in the bed of my truck. And now when I turn it on, it says wait front door open. Did something shake loose? because I don't see anything open
  • 1,326 Answers
The problem is that one of the front door inter lock switchs are not being actuated by one of the post's on the front door. It may have fallen off or got bent when you moved it. Look for a bent piece of meatel or bronken plastic and line it up with a **** on the front inside cover of the copier. If it is broken you may have to make a lever to stick into the hole/**** to cheat the inter lock switchs so that the front door is closed. You may have to use some tricky ideas to have the switch close and open with the front door. Just look for something bent or broken from the front door to find where to look. Good Luck
Posted on May 05, 2008
Another one is konica Minolta c300 given me a code of 3101
TO clear the code did you open and close the front door. Powering the machine on and off does not reset code open closing the front door does. If that does nor work recommend getting a new fuser/fixing unit.
Feb 26, 2015 | Konica Minolta Bizhub C300 All-In-One...
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
How can I clear Eror code C 301?
C - 301 Suction fan error.If not reset by open?close the front door,turn OFF the copier,press the Utility key and keep presed and turn ON the copier.Keep presed the key and wait will on the display appaire Trouble reset message.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Check the suction fan ventilator motor and the electrical connections.
Mar 27, 2013 | Konica Minolta Bizhub C364 Color Copier /...
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
The code is 1139
Memory board failure.Open the front door,turn OFF the copier wait 1 minutes close the door and turn ON the copier.
Feb 12, 2013 | Konica Minolta bizhub Office Equipment &...
C-2251
Please the copier machine type and model corect.
Jan 17, 2013 | Konica Minolta bizhub C450P Laser Printer
CODE SC23-05
This is an motor problem.Check toner bottle motor,developing motor and drum motor.Press the service reset switch or open/close the front door,turn off the machine wait 15 sec and turn on.
Sep 16, 2009 | Konica Minolta Office Equipment & Supplies
Reset
Simple reset is open and close front door. Otherwise turn the machine off (switch inside front door on the left) then wait 10 secs and switch back on
Regards
Taminol
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
188 people viewed this question
k24674
