Question about Maytag Neptune MDG5500AW Gas Dryer
MayTag Performa Model # PYET344AYW Will not heat or dry. Will Not turn on. Checked Fuse Box Already
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 23, 2010
Maytag performa dryer model #PYET344AYW wont stay running
Yes, I suspect the motor is at fault. The motor you need is available below!
Motor <----- CLICK HERE FOR THE CORRECT PART FOR YOUR MODEL
Aug 23, 2012 | Dryers
Need to know cu ft capacity of maytag performa dryer model pyet344ayw
Go to support on the Maytag website. Enter your model number, click on downloads, and select an owners manual.
murf427
Aug 04, 2012 | Maytag Dryers
Will not start
it is likely the Thermal Fuse, LA 1053 kit for Performa Electric Dryers. You have to open the case, remove the drum, Loose the back panel and remove the Heater element case. The Fusible Thermostat is on mounted on the side of the heating element case.
Feb 26, 2010 | Maytag Dryers
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
Maytag Neptune MDG5500AW Gas Dryer Logo
279 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
