Question about SanDisk Sansa e250 MP3 Player
When I try to access my sansa I get code 10, also a message stating there were no drivers for this device, this problem has only occured since I reformatted my computer.
  • 10,421 Answers
Status 0x00000e9
Many of the problems caused by programs lead to the emergence of the messages that come in shape
A fatal exception XX has occurred at XX.
Often occur, because the program on the problem of improper code required Processor Processor you make improper operation. Thus Windows displays this message to tell you so and ask you to tell him what it must do. In fact, these kinds of errors do not escape them and often lead to the closure of the program or you may have to restart the Windows operating system as a whole and therefore you will lose any unsaved data before, and you models for these errors.
He noted that in all the solutions that Snordha here we'll use the letter A to represent the floppy drive and the letter C to represent the hard drive that contains the Windows system device and the letter D to represent the CD-ROM drive, and that all the messages and solutions applicable to Windows XP and Windows Me unless stated one only.
Message:
A fatal exception 00 has occurred at XX
Meaning:
This error occurred because the processor tried dividing the number to zero which is the correct thing is sporty and therefore this letter appeared.
Solution:
Close the message and try to continue to use the program, if you can not close the program and then restart it again, or restart your computer if necessary College.
Message:
A fatal exception 0C has occurred at XX
Meaning:
This error occurred because one of the instructions stored within a certain part of memory called the stack (which parts of memory are reserved for programs to deal with the equipment and devices) tried to use portions of memory outside the specified part
Solution:
Try closing the program and restart your computer.
Message:
A fatal exception 0E has occurred at XX
Meaning:
This error occurred trying to access the data processor located on the Page page of memory RAM or virtual memory Virtual Memory, but discovered the absence of the page, or that the data has been improperly accessed.
Solution:
Close the message and try to continue to use the program, if the program can not switch off and then turn it on again, or restart your computer if necessary College.
Message:
A fatal exception 13 has occurred at XX
Or General Protection Fault
Meaning:
Fault of the same quality as previous mistakes, but did not specify why.
Solution:
Close the message and try to continue to use the program, If you can not do close the program and then restart it again, or restart your computer if necessary College.
All previous mistakes are supposed to occur at intervals spaced opposed, if repeated occurrence tried to determine when those errors occur, if they occur while the program is running, you may be able to solve the problem, remove and then reinstall the software again, or get a version upgrade him.
If you can not link between the error message and a program may be the reason why a file from the Windows system files or one of the device drivers Device Drivers, and test it restart your computer in the security mode Safe Mode, if you do not see the message usually be the cause of one of the players devices Thus you can access the latest version of the drivers in your device through the companies that produce them site on the web, and if the message persists often will be a problem in the Windows system itself, and therefore you will need to re-set the Windows system again.
Message:
System busy and appear on a blue screen
Meaning:
This message appears with the nature of the error usually as stated in previous communications with the program said that the cause of the problem is the system may be Windows itself, and ask you to wait until the system becomes less busier.
Solution:
Restart your computer, and if the error is repeated several times do to deal with him as we have seen in previous communications solutions.
Jun 20, 2013 | Computers & Internet
2GB Sansa e250 won't connect to my PC
Hello!!!
Try connecting it to different USB!!
Nov 02, 2008 | SanDisk Sansa Clip MP3 Player
Recognizing Sansa e250 on windows vista
Code 10 solution - uninstall all of your Sansa hardware completely, and then reinstall it
Jun 22, 2008 | SanDisk Sansa e250 MP3 Player
I keep getting an error message stating " a problem has occured in obtaining the devices secure clock
you didnt turn your mp3 player off safley when took off usb module this inturn had corrupted your files on mp3
reformat mp3 update software it has a microchip and all micros. need new updated drivers to run at peek conditions
May 09, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Code 10: Device Cannot Start
Code 10 refers to the operating system not having drivers to talk to the card. Without the drivers running windows cannot run the device.
Mar 08, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sansa e260
Code 10 means it cannot find the correct Driver for the device.
You PC needs to have XP / SP 2 and Windows Media Player 10 or higher.
If you do not have these programs then the driver is not on your PC.
Update these components and try connecting the device again.
Best of Luck.
Nov 18, 2007 | SanDisk Sansa e260 MP3 Player
Device Certificate
Here is the message I was getting; "Windows Media Player cannot synchronize or burn the protected file because the Player cannot verify that the license is valid. A problem occured while contacting the Internet to determine the current date and time." I looked at my device, Sansa e260, and the time was off by 1 hr. and 10 min. I corrected the time on the device and it worked fine after that......
Jun 12, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
